Right, air is all nice and dandy, but I want to go water as a ncie christmas present to myself. So what should I be looking to get, how much should I be looking to spend, etc etc?
My current rig is the following:
E6600
DS3
2GB Geil ULL RAM
X1800XT (although I have an X1900XT arriving shortly)
Got a Lian Li PC-7+II case, with 3 120mm ambers fitted.
Can someone spec me a decent set up that won't cost the earth (ideally a max of £150, might push to £200 if need be), that would be an improvement on my current air cooling (Zalman 9500 LED for the CPU, VF-900 on the GPU)
Want to get more out of my rig, but it seems a little hot at the moment, I was hoping water might help that. So what do you guys recommend, and what do I need to get on top of the kit?
Thanks for any help.
Socaddict
E6600
DS3
2GB Geil ULL RAM
Socaddict
out of stock at the moment though
my case is too small, lol and theres no way all the WC hardware will fit, i can't even find somewhere for my alphacool AP1510 pump (what a pump may i add, there not ****ing about that 6m lifting height!) any ideas?
