Break up and clog the system???? Where were you using it?
I have never heard of this happening before!
WJA96 said:You'll need to go some to beat a Reserator 2 - it's a VERY effective water cooler. It's as good as 2 Reserator 1's in series. Also have a google for "Alphacool Cape Cora 10" and "Preytek Serenity" as these are well-regarded alternative passive cooling systems. The Preytek is about to become available in the UK as a full kit for half the price of the Reserator 2 and it has proper water cooling components in the kit that you can upgrade with (it uses proper 3/8ths tubing for a start although it also uses G1/4 threads so you could make it 1/2" tubing if you wanted).
The AquaComputer PC-G70 triple radiator is available for about £235 if I recall correctly and the place that sells them will build it up properly with a Laing DDC pump and EK, Danger Den or Swiftech blocks for about another £100, so it's not cheap, but there will be very little that you couldn't cool with that set-up.
oli collett said:Excellent, i've contacted Preytek and they have put me in touch with their UK supplier and they are updating their site with the Serenity tonight (talk about efficiency!)
Is the Serenity going to be able to give me the kind of performance that the Reserator 2 will? I'm going to be using it to cool my 8800GTO and e6600, could you recommend me some decent blocks to go with them? I'm a bit unsure about fittings too, sorry i'm a bit new to this!
weescott said:Break up and clog the system???? Where were you using it?
