Do you mind if I throw in another random water cooling question rather than making a new post - with radiators is there any real difference between using a single 360mm, a 240 plus a 120, or 3x 120's? For example if your case cannot fit a 360, but can fit a 240 top plus a 120 rear.
And is there any difference in say a single 480 radiator, that goes CPU->GPU->Rad and then back to the start vs two 240 rads, where it goes CPU->Rad->GPU->Rad so that after each hot component you're dispersing some of the heat before getting to the next hot component. Or does that not matter?
