** Water Cooling Sale**
Do you mean the watercooling clearance section? As I cant see one only 2 x 140mm ones.
Ok so it is silver but it performs just like any other AX series rad and it's a damned good price
XSPC AX120 Single Fan Radiator (Silver) @ £26.99 inc VAT
The AX is a new premium radiator from XSPC. The AX series combines a high performance copper/brass radiator core with a compact and beautifully finished aluminium enclosure.
The AX's core is a high performance evolution of the popular EX radiator series. The core includes advances from the EX series like welded seam tubes and splitter fins, but with a thicker core (21mm vs 16mm) and increased surface area.
The radiator core is fitted inside of a 3mm thick, extruded and machined aluminium shell. The screw holes are precision cut by CNC which eliminates misaligned screw holes and gives 3mm of screw thread. The aluminium shell also provides a perfectly flat surface to mount the fans against, which eliminates air gaps and any need for a gasket.
All of this comes together to make what we believe is the best PC radiator on the market.
- 3mm Thick Aluminium Frame (No aluminium in the flow path)
- Copper and Brass Core
- Paint Free Core
- Chrome Plated G1/4" Ports
- RoHS Compliant
- Dimensions: 128 x 40 x 166mm (WxDxH) (46mm at ports)
- Weight: ~623 g
- Screws: 6-32 UNC
- Fans: 1 x 120mm (2x with push/pull)
Supplied 30mm and 6mm 6-32 UNC screws
Note: The AX Silver has an unpainted core, which will oxidise over time.
Was £46.99 Inc. VAT
Only £26.99 inc VAT.
ORDER NOW
No can do sorry sale is for getting movement items that have sat for a bit too long.
Worth a try. Any word on if the EK coolstream 240 rads will be in stock any time soon? Last time I asked there was no ETA :(
We've just noticed that the buy price on those is actually much higher than on any other sku, and I mean much higher not sure if it's becuase it's a popular sku and we've been shafted by the dollar rate on re-ordering or if it's always been expensive but there is no room for a discount on that sku
Anyway we will be pushing the price up at some point to match that so if you want that pair i'd buy it now.
If you check WCUK's website they are nearly £10 more expensive than we are and they buy from the same supplier as us.
However if you can do you 10% off any other Revolver Diamond 10 pack.
OK :D
Would you be able to do the discount on this set though?
http://www.overclockers.co.uk/showproduct.php?prodid=WC-153-PM&groupid=962&catid=2800&subcat=2801
