Yesterday I ordered my new system. Parts to be watercooled are a Q6600 and a 8800 GTX (I am using Nvidia
The setup I am thinking is as follows:
Swiftech MCP655 Pump
D-Tek FuZion
D-Tek FuZion Accelerator Nozzle Kit (£3.29 is it worth it? As reviews seem varied)
EK FC8800 8800GTX Acetal Top
ThermoChill PA120.3 Triple Radiator
EK Multioption RES 250 Rev.2 (or get the 150?)
All tubing and barbs will be 1/2".
Is the above setup going to be sufficient to overclock both cpu and gpu? If not should I get two 120.2s?
Also the other thing I am not sure about is it best to build the loop outside of the case test for leaks and then attach to hardware? If so just leave the loop on the desk and leave the pc on 24hrs with molex connected to the pump?
Also read on some forums people leave their watercooling of 24/7 so they don't get air in the system. I take it this isn't necessary as I can't leave mine on 24/7.
Thanks for your help guys.
).The setup I am thinking is as follows:
D-Tek FuZion
for quad's quite a few people reckon the nozzles make a difference but i dont have one on my fuzion , and it's just a idea but you could use 7/16" tubing which will make installing the jubilee or pvc hose clips abit easier on the cpu block , that is the only thing i dont like about the d-tek block the barbs are very close together with 1/2" tubing .
