Water Cooling
14 Nov 2005
May possibly be taking the plunge with water cooling system..which will be my first... had a look at the Zalman Reserator2 Fanless Water Cooling System and it seemed good. but have a couple of questions...
1) it looks like it's an actual case in itself..but..am i right in assuming this will stand up inside the case somewhere?
2) does it come with all the necessary blocks (CPU, VGA and Northbridge + ionized water) or do i have to purchase those seperatly?
many thanks
The Reserator Stands outside next to the case with the pipes going into the case through a PCI backplate or something. If I remeber correctly the Reserator 2 includes all the blocks you need. Although you would have better results with a custom kit :)
Hope that helps
