Water Cooling
13 Oct 2007
Cotswolds
Hi all,
For my graphics card, I have been considering either an 8800Ultra or an OC'd 8800GTX - however most of the ones that have high clock speeds are water cooled.
My question is, how easy is it to fit a water cooling system for the graphics card?
If you have any suggestions, they will be greatly appreciated! :p
Thanks:D
- just realised ive posted in the wrong bit, nevermind ;)
East enough... you will need sometime though and patience... yo might as well watercool the CPU if your watercooling your gfx card
Stelly
