Water flossers?
22 Dec 2002
Minehead
Hey all,
Just wondering if any of you use these as an alternative to traditional flossing? I'm quite tempted to pick up the waterpik ultra. Whilst expensive, it would save me buying floss tape and brushes (always seem to stab my gums with the brushes and it hurts!
Thanks
Can you not just swish mouthwash around? I hate flossing but i imagine the swish would be the same as the irrigator.
it won't get the crap between your teeth for this reason most people floss
Maybe one of these is for me then i only get residue on the floss from two teeth but it will bleed if i floss sometimes. They would need some serious power though to beat flossing or swishing surely?
This is now on my xmas list from the missus :) thanks
10-90 PSI sounds alright to me!
Yea i just looked at it and saw the PSI, My Christmas list already had the Emmi-Dent 6 from the same place. But i reckon i will add the Ultra-Pik. If these are half as good as the Corsodyl daily toothpaste with the mineral grit i got then i will be amazed.
That paste is brilliant, Best clean i ever had apart from the dentist.
Corsodyl Daily Gum & Tooth Paste - This stuff?
