- 1 Jul 2007
We have water hammer when anything turns off, unless it's a tap slowly. I'd need to have a crawl space investigation but the main incomer is secures solid, so don't think it's a lose pipe, unless it can vibrate from somewhere else?
The main comes up and splits almost instantly. One up to the attic, the next goes down under the floor. Up in the attic it drops from the 22mm-15mm then increases back in size, this then goes back down to first floor and then to bathroom under the flooring.
Could this reduction in pipe size be the cause?
Anything else to look out for apart from lose pipes?
