I'm thinking of going over to water cooling, never used it before and it looks so kool
get it? >.O kool...
Yeah but realy,
The main reasons I'm thinking about it is, silence! I've just read one of the threads and someone mentioned the RESERATOR 2. So I looked it up and, it has NO fans?! So it's litraly silent, not a single noise. Unlike when you go to buy a new fan and it says it's silent in the discription when realy it sounds like a blender.
My question is this, If you bought the Reserator 2, would I be able to add different components onto it? i.e not use the CPU block that comes with it and use a thermal take block instead? ( There's a nice block with LED's on it ^_^ ).
Second is, whats the performance like when connecting say, CPU, GPU and northbridge to it? I'm thinking the cold water would flow onto the CPU then the warm water from the CPU would just heat the GPU up because it hasn't been to the erm.. tank thing? to cool down? Then all the hot water from those 2 would be sent to the north bridge? Arg, complicated stuff wate cooling is ^_~.
/NachT
get it? >.O kool...Yeah but realy,
/NachT
not good value for money.
Also it's not really worth while watercooling the NB,just the cpu & vga
So would the reserator 2 be good for me now heh. Also my NB is kind'a extremely hot and I have no idea why
