Water Solution For A Bitfenix Prodigy
17 May 2009
ENGLAND
Can anyone suggest any budget water-cooling kits that would be suitable for a Bitfenix Prodigy case please.
I think the easiest and cheapest way would be to use a corsair h50/60/70 or its equivalent assuming you only want to cool the cpu.
EK H30 240mm kit.
was just looking into this as well... is that EK H30 240mm kit much of an improvement over the H100i / Antec 1220?
can it be expanded to include a gfx card?
Is it much of an improvement?.... No I don't think so. It can be expanded but you need more rad space fittings, tubing, graphics card block.
With regard to op. This is a budget kit which will fit. Be advised though you may find you need some angled fittings
