I have seen a few threads on other forums stating the current best performing setup is DDC with EK supreme but was wondering if this really was the consensus.
This forum normally goes for the D-tek!
Thats why im stuck![]()
Thanks for the info chaps, does make very interesting reading indeed, considering I have a PC-70 / Thermochill PA120.3 in top with a Laing D5 on the way.. hopefully![]()
Snip: I have the huge advantage of having an air-conditioned home office that runs at a very stable 18C summer and winter with very low humidity.
My preferred test rig comprises;
Laing DDC2 with Alphacool top and reservoir
Thermochill PA120.3
Choice of CPU block
1/2" R3400 Tygon tubing
The other option is to use a Lian Li G70 with a PA120.3 in the roof, but with a Laing D5 as that would allow me to vary the flow rate of water through the system, which might also very useful to know as the different blocks might respond better to different flow rates?
