I have been thinking about watercooling my E6300 for some time, it is currently at 3.1Ghz on 1.280volts however it does get up to 62c when running orthos small fft's. I am sure it will go further but I dont want to raise the temp any higher. I would also like to watercool the northbridge but at this time I have no plans to watercool my 8800gts. Although I am looking for performance I would like the setup to be fairly quiet.
After a little research i have put together the following list:
Swiftech Apogee GT extreme CPU block
Swiftech MCW30 chipset cooler
Swiftech Radbox
Swiftech MRES resevoir
Thermochill PA120.2
Alphacool Laing DDC Ultra pump with plexitop
MasterKleer 7/16 tubing (6ft)
I already have a couple of scythe 1200rpm 120mm fans which can be used on the rad.
I think the above is fairly high spec but it comes to about £220 (inc p&p+vat).
My other option is to get the swifteck apex ultra + the MCW30 chipset cooler for about £188.
I know custom is generally better but does anyone know how much of an improvement it will be over the swiftech kit. If its only going to be a couple of degrees at the same noise levels then I might as well save my money and go for the kit.
Plus, is there anything on the list I have missed off or anything that can be changed to save some money without comprimising performance.
Swiftech Radbox
Thermochill PA120.2
) I would go with the kit.
