Watercool-Kit or Custom
MikeTimbers said:
At the volts I'm having to use, I would guess my wattage is higher tahn on a C2D. The temps are load temps since idle temps are completely pointless to relate.
I thought that they would probably be load temps but it was worth checking anyway. If I can get +15c over ambient I will be quite happy.
Going to order the swiftech kit this afternoon but having second thoughts about the chipset block. I am currently cooling my NB with a HR-05 which has a akasa 80mm fan strapped to it. My NB volts are at 1.7 (P5N-E SLI) and I have had no issues with it what so ever. Is the chipset block worth it or can I save another £17.
Very few people bother with water-cooling their chipsets. Any after-market northbridge heatsink will be more than enough unless you're doing insane clocking (LN2 etc.)
