- 16 Nov 2012
Hi all, my first post
So, I've been building PC's for years now as part of my job and recently decided to upgrade from my beloved Q6600. She served me well, but the i7 is a worthy upgrade, and I've definitely enjoyed building it.
I'm currently using a CM-Storm Trooper case, with a Coolermaster TPC-800 heatsink, with 2x 120mm Coolermaster fans. Currently got it on with Arctic Silver 5, which has had about 2 weeks to "bed in".
My problem is, that I can happily overclock it to say 4.2 - 4.3 without too much difficulty, but once I reach 4.5, the temps on Intel Burn Test are a bit too high for my liking. Idle is around 50-56 degrees (doesn't seem to matter what I do with my fan speeds), and under load it reaches high 80s or even low 90s if my room is hot. I had it running for a couple of days at 4.5, but I'm not happy with it going that high. Average temps on normal load (e.g. gaming) were around 75.
I attempted 4.6ghz.. but decided 101 degrees max was a bit high. I had to use 1.29v to keep it stable. I reduced it back very quickly, needless to say.
Now I've done some googling, and found lots of people have watercooled the 3770k, but I'm not sure what I could expect to run it on 24/7 with reasonable temps. I'd hope for a bit more than 4.5ghz... ideally.
Could anybody offer me any advice please? I've built dozens of PCs over the years... but I've never once actually done or worked on a watercooled PC, so this is a little out of my area. It is something I've always wanted to try though
Thanks very much in advance!
.Thanks very much in advance!
