Watercooling advice
Hahaha get that a lot. I know the HAF is practical etc but ive got to be honest. I just didnt like it. Not into the industrial look on cases. Im kind of wishing I bought the Obsidian but im buggered if im paying for another case within weeks.
IMO the HAF is FUGLY! My TJ07 looks epic. The cosmos S is a pretty good case aswell
so this is the line up
hopefully going to order tomorrow so chime in now lol if its wrong haha
Scythe Gentle Typhoon 120mm Case Fan 1450 RPM x 3
EK Supreme HF Easy Mount CPU Waterblock
EK FC590 GTX Full Cover Waterblock for NVIDIA 590 GTX
Masterkleer Hi-Flex 7/16" ID - 5/8" OD (11-16mm) Tubing : Clear
EK PSC 1/4" Thread Compression Fitting for 7/16" ID - 5/8" OD Tubing : Silver
1/4" Thread 90° Rotary Compression Fitting for 7/16" ID - 5/8" OD (11-16mm) Tubing : Silver
Mayhems Dye 5ml Dropper Bottle : Deep Blue
Arctic Cooling MX-4 Thermal Compound 4g
XSPC RS Series 360mm Triple Radiator : RS360
500ml Squeezy Bottle for filling Watercooling Systems
Tubing Cutter
Pulse Modding 99.9% Silver Kill Coil
XSPC X2O 750 L/ph 12V Pump Rev2 with Dual Drive Bay Multi Fascia Acrylic Reservoir
£353.76
Do i really need another rad? Can you think of anything that would do a better job / save me some pennies????
cheers guys!
what about the
Hardware Labs Black Ice® GT Stealth Lite 360mm Triple Radiator : GTS360-LITE
instead of the rs360?
Tubing Cutter
£353.76
cheers guys!
Instead of the XSPC rad or the GTS (stealth), I would go for the SR-1 as it has really dense fins, meaning the fans can be at low RPM's whilst it cools efficiently.It's worth the extra money
The squeezy bottle is pointless a funnel will be better.
Make sure the tubing cutter is a good one (around £10) if you go for one.
And for the fans, I would recommend the Enermax apollishes. they look amazing and are silent!
What fan controller are you getting? And where's the water?
Wouldnt dense fins imply that you'd need to run fans at high RPM to push air through the rad?
Squeezy bottle is far from pointless. I don't have one myself but I can see that it would speed up the process of filling and minimise chances of spillage.
Recommending fans because they look great and have flashing lights is hardly helping the OP maximise his cooling capacity. Certain fans are better suited to particular rads due to static pressure. Maybe he'd be better sticking with the Scythe GTs he has selected or he may want to consider Akasa Vipers. Unfortunately neither have flashing lights but, hey ho, they get the job done.
Yep im going to stick with the fans i selected and the rad.
Squeezy bottle is still going on the order. For the couple of quid it seems like a winner to me.
