Watercooling help required :(
26 Dec 2009
Norwich
So ive built my first ever water cooling loop which consists of:
Ek evo nickel block.
Monsoon rad d5 pump combo. Pump is set to 4
Ek 360 rad
for some reason the water isnt cycling and won't get past the rad it will just tickle in
My setup is pump > block > rad > res.
Any idea why this happening?
I also have a fill tube connected to the top of the res.
Thanks in advance.
Cool. What's the best way to remove It? Ive tried tilting thr case for a little while but when put back down it goes back to the same state.
Rotate and shake it like a mofo from all angles, then run the pump with the lid of the reservoir for a bit. Then repeat. Then repeat. And do that until all the air has gone. You should not have gaps in the fluid like that.
Might be worth opening up the CPU block to check if anything is blocking the fins. A few people on here also had the jet plate in the wrong orientation blocking flow.
Fill the res , then remove the fill tube ( you creating an air lock with the fill tube still attached ), switch on till the res empties.
Then just keep repeating the above
That's exactly what it was! The block was full of crap, I cleaned it and reassembled and now the flow rate is fine.
Thanks for all the help guys.
