hello guys
i'm new to watercooling i currently have a corsair h50 cooling my i7 920 @ 4.2ghz @ 1.392vcore and under prime its reaching 97c on the cores i've let it run for 4hours to make sure it was semi stable. thing is i cant accept these temps which what brings me here, i have done/stil doing abit of research, i have all ready seen a cpu block in MM (heatkiller 3.0 Cu) i basically want the cheapest components to try and keep my cpu cool not to bothered about cooling my gpu just yet. can any 1 spec me a decent set up with a budget in mind... ideally i would like to keep my cpu in the 70 full load
my current system is
i7 920 @ 4.2ghz
6gb corsair xms
ga ex58 ud3r
ati 5850
coolermaster cm690 II advanced (the cm690 II adv can fit 240mm rad top and bottom, think i have read some where if you have it in the top it needs to be a stealth rad for mobo clearance.)
this is what i have came up with so far
EK CoolStream Radiator XT 240 (120.2)
XSPC 200 Bay Reservoir & Pump - Clear
Masterkleer 7/16" Tubing UV Blue Transparant - 2m
EK 12mm (1/2") G1/4 High-Flow Fitting x 4
XSPC Tubing Clip For 1/2" and 7/16" Hose x4
HEATKILLER® CPU Rev3.0 1366
i7 920 @ 4.2ghz
6gb corsair xms
ga ex58 ud3r
ati 5850
