Watercooling.. how much fluid?
30 Jan 2017
Lincs
As the title says really... I now have prettyy much all parts sorted to start on this great adventure: CPU block, GPU block, 140 res, 360 rad and 240 rad.
Do you think 1ltr of fluid is enough?
Many thanks, and Merry Christmas.
1l would normally be enough for a standard loop, what type of fluid are you using? Water is so cheap you might as well buy 5l for £3-£4 and then just dose it with the right amount of biocide/corrosion inhibitor.
Get 2l and you have enough for topping up if 1l is not enough- I’ve got 2 360 rads in loop with gpu and cpu with 250ml res and is just about the 1l mark
That's good to know mate, sounds like your loop is a higher capacity than mine then so probably 1 ltr is plenty. I'll get 2 anyway to be sure :)
I have a 30mm 120 radiator and a 45mm thick 360, plus CPU and GPU blocks with 250ml reservoir. My loop uses 1.1l of water. I found out while flushing with distilled by measuring as i filled it.
It's a really inconvenient size so i used 1l of premix plus 100ml of distilled!
Always get 2l if you think you might be close.
My old loop took a shade under 1.5l but that was with 55x360 rad and 45x280 with large res and lots of tubing
