here are the parts i have found i want to purcase :
Swiftech Laing D5 Vario MCP655 12V DC Pump
EK-Supreme HF - Full Nickel CPU Water Block [3830046990235]
Black Ice GT Stealth 240 Radiator
EK Multioption Reservoir X2 150 Advanced [3831109840078]
Akasa AK-FN058 Apache Black Super Silent 120mm Fan - 4 Pin PWM x2
Masterkleer tubing PVC 3/8" UV-active blue
I have an antec 1200 case with Intel Core i5(Sandybridge), i only want to cool my i5 for now.
I am confused on which barbs and connectors i will need to use?
The pump comes with 1/2 fitting will this be ok to use in this loop?
Any help or advice on making the loop better will be appreciated
Thnaks Aaron
Thnaks Aaron
Thanks for all replyes cant wait to get this built is there any improvments i could make before i make an order
