Hi,
We have a wide variety of water cooling bundles that have been created to give even the most novice of user all the equipment they need to water cool there system.
If you are interested in water cooling but are unsure what you will need or if you just want a basic loop to make you CPU cooler and your system to look better these are very good options.
The bundles all come in different levels depending on what you do with the system. We have basic bundles that are designed for the normal use, some for high usage and high end CPU's and we have performance bundles for people who are interested in overclocking.
Below are some of the kits that we sell and I'm sure we have something to get you started.
EK Water Blocks EK-KIT L120 (R2.0) Performance Watercooling Kit @ £179.99 inc VAT
The EK-KIT L120 water cooling kit is a powerful kit for all users who seek simple, yet quality and effiicient all-in-one solution, assembled from selected market proven components.
Revision 2.0 (R2.0) further improves the quality and reliability of the original L series kits, introduced in 2013.
EK-KIT L120 R2.0 includes:
- universal CPU water block: EK-Supremacy MX (incl. mounting- & thermal material)
- radiator: EK-CoolStream PE 120 (Single)
- radiator fan: EK-Vardar F3-120 1850rpm (1pcs)
- water pump / reservoir unit: EK-XRES 100 DDC MX 3.1 PWM
- tubing: EK-Tube ZMT Matte Black 15,9/9,5mm (2 meters)
- compression fittings: EK-ACF Fitting 10/16mm Nickel (6 pcs)
- coolant concentrate:EK-Ekoolant EVO Clear (100mL; for 1L of coolant)
- additional pump holder (120mm fan hole pattern)
- Y-cable splitter: EK-Cable Y-Splitter 3-Fan PWM (10cm)
- ATX bridging plug
EK-Supremacy MX UNI is a reduced cost variant of EK-Supremacy EVO flagship performance water block, introduced in 2014. It has been designed to lower the production costs yet still offer premium hydraulic- and thermal performance at the best price.
EK-CoolStream PE series radiator fits in majority of computer chassis and will succesfully take the heat out of your system. In combination with in-house developed EK-Vardar high-static pressure fan the unit provides silent operation with great coooling performance.
EK-XRES 100 DDC MX 3.1 PWM water pump / reservoir combo is also brand new, cost-reduced variant of the market proven EK-XRES DDC pump/reservoir combo unit, powered by Laing DDC 3.1 PWM (6W) pump.
High quality EK made ZMT (Zero Maintainance Tubing) EPDM rubber tubing ensures long lasting operation and does not suffer from plasticizer leaching effect, very common with regular PVC tubing.
Majority of components have been pre-assembled resulting in quick and painless installation procedure. This kit can also be upgraded with an additional EK-VGA Supremacy, EK-FB, EK-FC or EK-RAM series waterblocks!
This liquid cooling kit is compatible with the following CPU sockets:
- Intel LGA-775
- Intel LGA-1366
- Intel LGA-1150/1151/1155/1156
- Intel LGA-2011(-3)
- AMD Sockets: 939, 754, 940
- AMD Sockets: AM2(+), AM3(+), FM1, FM2(+)
Made in Slovenia - Europe!
PLEASE NOTE:
- List of components may be subject to change in future according to EKWB's best practices.
- Distilled water needed to dilute the cooling liquid concentrate is not included.
- EK recommends using EK-KIT L120 R2.0 for CPU water cooling only. In order to add more water blocks to the loop it is recommended to increase the cooling capacity by adding additional EK-Coolstream series radiator to the loop.
Only £179.99 inc VAT.
ORDER NOW
EK Water Blocks EK-KIT L240 (R2.0) Performance Watercooling Kit @ £199.99 inc VAT
The EK-KIT L240 R2.0 water cooling kit is a powerful kit for all users who seek simple, yet quality and effiicient all-in-one solution, assembled from selected market proven components.
EK-KIT L240 R2.0 includes:
- radiator: EK-CoolStream PE 240 (Dual)
- radiator fan: EK-Vardar F3-120 1850rpm (2pcs)
- coolant concentrate: EK-Ekoolant EVO Clear (100mL; for 1L of coolant)
- ATX bridging plug
- Intel LGA-775
- Intel LGA-1366
PLEASE NOTE:
- EK recommends using EK-KIT L240 R2.0 for CPU water cooling only. In order to add more water blocks to the loop it is recommended to increase the cooling capacity by adding additional EK-Coolstream series radiator to the loop.
Only £199.99 inc VAT.
ORDER NOW
EK Water Blocks EK-KIT L360 (R2.0) Performance Watercooling Kit @ £209.99 inc VAT
The EK-KIT L360 R2.0 water cooling kit is a powerful kit for all users who seek simple, yet quality and effiicient all-in-one solution, assembled from selected market proven components.
EK-KIT L360 R2.0 includes:
- radiator: EK-CoolStream PE 360 (Tripple)
- radiator fan: EK-Vardar F3-120 1850rpm (3pcs)
- ATX bridging plug
- Intel LGA-775
- Intel LGA-1366
PLEASE NOTE:
- EK recommends using EK-KIT L360 R2.0 for CPU water cooling only. In order to add more water blocks to the loop it is recommended to increase the cooling capacity by adding additional EK-Coolstream series radiator to the loop.
Only £209.99 inc VAT.
ORDER NOW
EK Water Blocks EK-KIT P240 Performance Watercooling Kit @ £246.95 inc VAT
The EK-KIT P240 is the ultimate liquid cooling kit dedicated to all users who seek the best price-performance ratio on the market! Everything you need to assemble your first custom loop. You don't have to worry about compatibility issues or being nervous about the right amount of fittings or tube length. If you are a beginner, this is a great place to start!
This kit brings the following components, selected from our wide range of quality products:
EK-Supremacy EVO - universal CPU water block that fits all modern CPU sockets with a universal mounting mechanism that offers error-preventing, tool-less installation. The result is an easy installation which brings perfect performance every time. EK-Supremacy EVO is our flagship CPU water block and it is truly the best product for performance seeking enthusiasts.
EK-CoolStream PE 240 radiator - it gives this kit its name - offers best cooling capacity in the 40mm thick radiator class: Double stack copper fins provide massive surface area while the parallel flow cooling chambers reduce hydraulic flow resistance to a minimum. Built for EK-Vardar 120mm high static pressure fans, these radiators are optimized for maximum heat dissipation across entire fan operational range thus delivering exceptional performance at both low- and high airflow operation.
EK-Vardar - industrial grade high-static pressure computer cooling fan, designed and built primarily for highest-performance computer liquid cooling systems. EK-Vardar is simply the best choice for computer radiator cooling as it provides unmatched performance throughout entire operating range.
EK-XRES 140 Revo D5 PWM (incl. pump) - high-performance water cooling pump with integrated reservoir. The core of the unit is the market-proven Xylem D5 PWM water pump. The unit features a fully rounded design thus offering greater usability, allowing installation at any angle within 360° of rotation. Special rubber shock absorber is used to de-couple the main pump body from the mounting clip for silent operation, free of vibration induced noise. Additionally, horizontal and vertical positioning are supported for easier tube routing possibilities.
PrimoChill PrimoFlex™ Advanced LRT™ - 2 meters of the premium quality PVC tubing, guaranteed to be free of plasticizer leaching related issues.
EK-Ekoolant EVO - brand new coolant, evolved from original EK-Ekoolant, designed specifically for computer liquid cooling systems with 3-year shelf life from date of bottling. It comes in a weight-saving 100mL concentrated form, which - dilluted with 900mL distilled water (not included) - forms the high performance cooling mixture for your liquid cooling loop.
Kit is easy to install, use and maintain, a thorough installation manual is included. Every item in this kit can be purchased separately, further descriptions and specifications of individual items can be found in EK webshop.
Majority of components have been pre-assembled resulting in quick and painless installation procedure. Once installed, this kit is a full custom loop solution. It can be upgraded with additional water blocks and components, such as additional radiators.
EK-KIT P240 complete list of items:
- Universal CPU water block: EK-Supremacy EVO (incl. LED diode, mounting- & thermal material)
- Radiator: EK-CoolStream PE 240 (Dual)
- Radiator fan: EK-Vardar F3-120 (1850rpm) (2pcs)
- Water pump-reservoir combo: EK-XRES 140 Revo D5 PWM (incl. pump)
- Tubing: PrimoChill PrimoFlex™ Advanced LRT™ 13/10mm (2 meters)
- Compression fittings: EK-ACF Fitting 13/10mm - G1/4 Nickel (6 pcs)
- Coolant concentrate:EK-Ekoolant EVO Clear (100mL; for 1L of coolant)
- Y-cable splitter: EK-Cable Y-Splitter 2-Fan PWM (10cm)
- ATX bridging plug
This water cooling kit is compatible with the following CPU sockets:
- Intel LGA-775
- Intel LGA-1366
Only £246.95 inc VAT.
ORDER NOW
EK Water Blocks EK-KIT P280 Performance Watercooling Kit @ £261.95 inc VAT
The EK-KIT P280 is the ultimate liquid cooling kit dedicated to all users who seek the best price-performance ratio on the market! Everything you need to assemble your first custom loop. You don't have to worry about compatibility issues or being nervous about the right amount of fittings or tube length. If you are a beginner, this is a great place to start!
EK-CoolStream CE 280 radiator - it gives this kit its name - offers best cooling capacity in the 45mm thick radiator class: Double stack copper fins provide massive surface area while the parallel flow cooling chambers reduce hydraulic flow resistance to a minimum. Built for EK-Vardar 140mm high static pressure fans, these radiators are optimized for maximum heat dissipation across entire fan operational range thus delivering exceptional performance at both low- and high airflow operation.
EK-KIT P280 water cooling kit includes following items:
- Radiator: EK-CoolStream CE 280 (Dual)
- Radiator fan: EK-Vardar F2-140 (1600rpm) (2pcs)
- Tubing: PrimoChill PrimoFlex™ Advanced LRT™ 10/13mm (3/8'' - 1/2'') (2 meters)
- Compression fittings: EK-ACF Fitting 10/13mm (3/8'' - 1/2'') - G1/4 Nickel (6 pcs)
- ATX bridging plug
- Intel LGA-775
- Intel LGA-1366
Only £261.95 inc VAT.
ORDER NOW
EK Water Blocks EK-KIT P360 Performance Watercooling Kit @ £265.99 inc VAT
The EK-KIT P360 is the ultimate liquid cooling kit dedicated to all users who seek the best price-performance ratio on the market! Everything you need to assemble your first custom loop. You don't have to worry about compatibility issues or being nervous about the right amount of fittings or tube length. If you are a beginner, this is a great place to start!
EK-CoolStream PE 360 radiator - it gives this kit its name - offers best cooling capacity in the 40mm thick radiator class: Double stack copper fins provide massive surface area while the parallel flow cooling chambers reduce hydraulic flow resistance to a minimum. Built for EK-Vardar 120mm high static pressure fans, these radiators are optimized for maximum heat dissipation across entire fan operational range thus delivering exceptional performance at both low- and high airflow operation.
EK-KIT P360 water cooling kit includes:
- Radiator: EK-CoolStream PE 360 (Triple)
- Radiator fan: EK-Vardar F3-120 (1850rpm) (3pcs)
- ATX bridging plug
- Intel LGA-775
- Intel LGA-1366
Only £265.99 inc VAT.
ORDER NOW
EK Water Blocks EK-KIT X240 High Performance Watercooling Kit @ £229.99 inc VAT
The EK-KIT X240 is the flagship performance water cooling kit dedicated to all users who seek best performing, yet quality built and efficient all-in-one solution.
EK-Supremacy EVO is a universal CPU water block that fits all modern CPU sockets with a universal mounting mechanism that offers error-preventing, tool-less installation. The result is a perfect installation which results in perfect performance every time. EK-Supremacy EVO is truly the best product for performance seeking enthusiasts.
EK-CoolStream XE 240 is the highest performance radiator. Due to it's thickness of 64mm please make sure you computer chassis can accomodate it (EK also offers radiator holders for external mounting).
EK-Vardar is the industrial grade high-static pressure computer cooling fan, designed and built primarily for highest-performance computer liquid cooling systems. EK-Vardar is simply the best choice for computer radiator cooling as it provides unmatched performance throughout entire operating range.
EK-DDC 3.2 PWM Elite Edition is the highest performance water pump that has been proven by the enthusiast of the water cooling community. It comes with Clean CSQ high performance volute X-TOP and EK-DDC Heatsink Housing to further improve the performance, durability and overall impression of these units.
This kit comes with 2 metres of PrimoChill PrimoFlex™ Advanced LRT™ which is the premium quality PVC tubing, guarantee to be free of plasticizer leaching related issues.
EK-Ekoolant EVO is a brand new coolant, evolved from original EK-Ekoolant, designed specifically for computer liquid cooling systems with 3-year shelf life from date of bottling. It comes in a weight-saving 100mL concentrated form, which - diluted with 900mL distilled water (not included) - forms the high performance cooling mixture for your liquid cooling loop.
Kit is easy to install, use and maintain, a thorough installation manual is included. Further descriptions and specifications of individual items can be found in EK webshop.
Majority of components have been pre-assembled resulting in quick and painless installation procedure. This kit can also be upgraded with an additional EK-Thermosphere, EK-FB, EK-FC or EK-RAM series waterblocks!
EK-KIT X240 water cooling kit includes following items:
- universal CPU water block: EK-Supremacy EVO (incl. LED diode, mounting- & thermal material)
- radiator: EK-CoolStream XE 240 (Double)
- radiator fan: EK-Vardar F3-120 (1850rpm) (2pcs)
- water pump: EK-DDC 3.2 PWM Elite Edition (incl. pump holders)
- reservoir: EK-RES X3 150
- tubing: PrimoChill PrimoFlex™ Advanced LRT™ 13/10mm (2 meters)
- compression fittings: EK-CSQ Fitting 13/10mm - G1/4 Nickel (8 pcs)
- ATX bridging plug
- Intel LGA-775
- Intel LGA-1366
PLEASE NOTE:
- Please make sure you chassis can accommodate thick radiator!
- EKWB recommends use of fan regulation adapters in case your motherboard does not support fan speed regulation. Such devices are not included in kit. They can be purchased separately here.
Only £229.99 inc VAT.
ORDER NOW
EK Water Blocks EK-KIT X360 High Performance Watercooling Kit @ £281.99 inc VAT
The EK-KIT X360 is the flagship performance water cooling kit dedicated to all users who seek best performing, yet quality built and efficient all-in-one solution.
EK-CoolStream XE 360 is the highest performance radiator. Due to it's thickness of 64mm please make sure you computer chassis can accomodate it (EK also offers radiator holders for external mounting).
EK-KIT X360 water cooling kit includes:
- radiator: EK-CoolStream XE 360 (Triple)
- radiator fan: EK-Vardar F3-120 (1850rpm) (3pcs)
- ATX bridging plug
- Intel LGA-775
- Intel LGA-1366
PLEASE NOTE:
Only £281.99 inc VAT.
ORDER NOW
XSPC RayStorm D5 AX240 WaterCooling Kit @ £229.99 inc VAT
Raystorm D5 AX240 Watercooling Kit gives a complete package of high performance watercooling solutions for both Intel and AMD cooling.
Contents:-
- RayStorm Intel CPU Waterblock
- D5 Dual Bay Reservoir
- D5 Vario Pump
- AX240 Dual Radiator
- G1/4" to 7/16" Compression Fittings (Black Chrome) x6
- XSPC 1650rpm 120mm Fan x2
- 120mm Fan Grill (Black) x2
- Intel and AMD RayStorm Brackets
- Socket 1366 and 1150/1155/1156 Backplates
- Socket AM2 and AM3 mounting kit
- 80mm to 120mm Radiator brackets
- 3mm Twin Blue LED with 4Pin Molex
- 5mm Blue LED with 4Pin Molex
- 2 Meters of Clear 7/16" Hose
- 24pin ATX Bridge Tool
- K2 Thermal Paste
Specification:-
- AMD Sockets: AM2, AM2+, AM3, AM3+
- Intel Sockets: LGA2011, LGA1366, LGA1156, LGA1155, LGA1150
ORDER NOW
XSPC RayStorm D5 AX360 WaterCooling Kit @ £249.95 inc VAT
Contents:-
- D5 Vario Pump
- AX360 Dual Radiator
- XSPC 1650rpm 120mm Fan x3
- 120mm Fan Grill (Black) x3
- 2 Meters of Clear 7/16? Hose
- K2 Thermal Paste
Supports:-
Only £249.95 inc VAT.
ORDER NOW
XSPC RayStorm D5 Photon RX240 V3 WaterCooling Kit @ £269.99 inc VAT
Kit Contents:-
- D5 Photon 170 Tube Reservoir
- D5 Vario Pump
- RX240 V3 Dual Radiator
- G1/4? to 7/16? Compression Fittings (Black Chrome) x6
- K2 Thermal Paste
Supports:-
- AMD Sockets AM2, AM2+, AM3, AM3+, FM1, FM2
- Intel Sockets LGA2011, LGA1366, LGA1156, LGA1155, LGA1150
Only £269.99 inc VAT.
ORDER NOW
XSPC RayStorm D5 Photon RX360 V3 WaterCooling Kit @ £299.99 inc VAT
Kit Contents:-
- D5 Vario Pump
- RX360 V3 Triple Radiator
- K2 Thermal Paste
Supports:-
Only £299.99 inc VAT.
ORDER NOW
EK Water Blocks EK-KIT S120 Performance Watercooling Kit @ £146.99 inc VAT
The EK-KIT S120 is a compact starter liquid cooling kits dedicated to all users who seek the best performing, market proven components for highest chassis compatibility. Designed for smaller cases with slim radiator in mind, the S kits are a great choice for every liquid cooling beginner and people doing small and mini ITX builds.
Kit brings everything you need to assemble your first custom loop. You don't have to worry about compatibility issues or being nervous about the right amount of fittings or tube length. If you are a beginner, this is a great place to start!
EK-Supremacy MX - universal CPU water block that fits all modern CPU sockets with a universal mounting mechanism that offers error-preventing, tool-less installation. The result is an easy installation which brings perfect performance every time. EK-Supremacy EVO is our flagship CPU water block and it is truly the best product for performance seeking enthusiasts.
EK-CoolStream SE 120 radiator - it gives this kit its name - offers best cooling capacity in the 25mm thick radiator class: copper fins provide massive surface area while the parallel flow cooling chambers reduce hydraulic flow resistance to a minimum. Built for EK-Vardar 120mm high static pressure fans, these radiators are optimised for maximum heat dissipation across entire fan operational range thus delivering exceptional performance at both low- and high airflow operation.
EK-XRES 100 SPC-60 MX PWM (incl. pump) - is a value oriented water cooling pump reservoir combo. It has been designed to lower the production costs yet still offer premium hydraulic performance at the best price. PWM control allows for automatic pump speed regulation depending on your CPU temperature. Full performance on demand or whisper quiet operation in idle mode!
PrimoChill PrimoFlex™ Advanced LRT™ - 2 meters of the premium quality clear PVC tubing, guaranteed to be free of plasticiser leaching related issues.
EK-KIT S120 water cooling kit includes:
- Universal CPU water block: EK-Supremacy MX UNI (incl. LED diode, mounting- & thermal material)
- Radiator: EK-CoolStream SE 120 (Slim Single)
- Radiator fan: EK-Vardar F3-120 (1850rpm) (1pcs)
- Water pump-reservoir combo: EK-XRES 100 SPC-60 MX PWM (incl. pump)
- ATX bridging plug
- Intel LGA-775
- Intel LGA-1366
Only £146.99 inc VAT.
ORDER NOW
ek water blocks ek-kit s240 performance watercooling kit @ £154.99 inc vat
the ek-kit s240 is a compact starter liquid cooling kits dedicated to all users who seek the best performing, market proven components for highest chassis compatibility. designed for smaller cases with slim radiator in mind, the s kits are a great choice for every liquid cooling beginner and people doing small and mini itx builds.
kit brings everything you need to assemble your first custom loop. you don't have to worry about compatibility issues or being nervous about the right amount of fittings or tube length. if you are a beginner, this is a great place to start!
this kit brings the following components, selected from our wide range of quality products:
ek-supremacy mx - universal cpu water block that fits all modern cpu sockets with a universal mounting mechanism that offers error-preventing, tool-less installation. the result is an easy installation which brings perfect performance every time. ek-supremacy evo is our flagship cpu water block and it is truly the best product for performance seeking enthusiasts.
ek-coolstream se 240 radiator - it gives this kit its name - offers best cooling capacity in the 25mm thick radiator class: copper fins provide massive surface area while the parallel flow cooling chambers reduce hydraulic flow resistance to a minimum. built for ek-vardar 120mm high static pressure fans, these radiators are optimised for maximum heat dissipation across entire fan operational range thus delivering exceptional performance at both low- and high airflow operation.
ek-vardar - industrial grade high-static pressure computer cooling fan, designed and built primarily for highest-performance computer liquid cooling systems. ek-vardar is simply the best choice for computer radiator cooling as it provides unmatched performance throughout entire operating range.
ek-xres 100 spc-60 mx pwm (incl. pump) - is a value oriented water cooling pump reservoir combo. it has been designed to lower the production costs yet still offer premium hydraulic performance at the best price. pwm control allows for automatic pump speed regulation depending on your cpu temperature. full performance on demand or whisper quiet operation in idle mode!
primochill primoflex™ advanced lrt™ - 2 meters of the premium quality clear pvc tubing, guaranteed to be free of plasticiser leaching related issues.
ek-ekoolant evo - brand new coolant, evolved from original ek-ekoolant, designed specifically for computer liquid cooling systems with 3-year shelf life from date of bottling. it comes in a weight-saving 100ml concentrated form, which - dilluted with 900ml distilled water (not included) - forms the high performance cooling mixture for your liquid cooling loop.
kit is easy to install, use and maintain, a thorough installation manual is included. every item in this kit can be purchased separately, further descriptions and specifications of individual items can be found in ek webshop.
majority of components have been pre-assembled resulting in quick and painless installation procedure. once installed, this kit is a full custom loop solution. it can be upgraded with additional water blocks and components, such as additional radiators.
ek-kit s240 water cooling kit includes:
- universal cpu water block: ek-supremacy mx uni (incl. led diode, mounting- & thermal material)
- radiator: ek-coolstream se 240 (slim dual)
- radiator fan: ek-vardar f3-120 (1850rpm) (2pcs)
- water pump-reservoir combo: ek-xres 100 spc-60 mx pwm (incl. pump)
- tubing: primochill primoflex™ advanced lrt™ 10/13mm (3/8'' - 1/2'') (2 meters)
- compression fittings: ek-acf fitting 10/13mm (3/8'' - 1/2'') - g1/4 nickel (6 pcs)
- coolant concentrate:ek-ekoolant evo clear (100ml; for 1l of coolant)
- y-cable splitter: ek-cable y-splitter 2-fan pwm (10cm)
- atx bridging plug
this water cooling kit is compatible with the following cpu sockets:
- intel lga-775
- intel lga-1366
- intel lga-1150/1151/1155/1156
- intel lga-2011(-3)
- amd sockets: 939, 754, 940
- amd sockets: am2(+), am3(+), fm1, fm2(+)
only £154.99 inc vat.
ORDER NOW
ek water blocks ek-kit s360 performance watercooling kit @ £177.95 inc vat
the ek-kit s360 is a compact starter liquid cooling kits dedicated to all users who seek the best performing, market proven components for highest chassis compatibility. designed for smaller cases with slim radiator in mind, the s kits are a great choice for every liquid cooling beginner and people doing small and mini itx builds.
ek-coolstream se 360 radiator - it gives this kit its name - offers best cooling capacity in the 25mm thick radiator class: copper fins provide massive surface area while the parallel flow cooling chambers reduce hydraulic flow resistance to a minimum. built for ek-vardar 120mm high static pressure fans, these radiators are optimised for maximum heat dissipation across entire fan operational range thus delivering exceptional performance at both low- and high airflow operation.
ek-kit s360 water cooling kit includes:
- radiator: ek-coolstream se 360 (slim tripple)
- radiator fan: ek-vardar f3-120 (1850rpm) (3pcs)
- y-cable splitter: ek-cable y-splitter 3-fan pwm (10cm)
- atx bridging plug
- intel lga-775
- intel lga-1366
only £177.95 inc vat.
ORDER NOW
XSPC Raystorm Pro Ion AX240 Watercooling Kit @ £159.95 inc VAT https://www.overclockers.co.uk/xspc-raystorm-pro-ion-ax240-watercooling-kit-wc-409-xs.html
RayStorm watercooling kits provide high cooling performance, low noise levels and excellent reliability. This kit is easily expandable allowing you to add a GPU waterblock and an additional radiator.
The kit includes all the components you need and a step by step guide, showing you how to watercool your computer. All you need to add is coolant.
Kit Contents:
RayStorm Pro CPU Waterblock (Intel only)
Ion Pump/Reservoir
AX240 Dual Radiator
Socket 1366 and 115X Backplates
80mm to 120mm Radiator Bracket
Twin 3mm White LED
5mm White LED
K3 Thermal Paste
Supports Intel Sockets: LGA2011, LGA2011-3, LGA1366, LGA1150, LGA1151, LGA1154, LGA1155, LGA1156
Only £159.95 inc VAT.
ORDER NOW
XSPC Raystorm Pro Ion AX280 Watercooling Kit @ £169.99 inc VAT https://www.overclockers.co.uk/xspc-raystorm-pro-ion-ax280-watercooling-kit-wc-40a-xs.html
Kit Contents:
Ion Pump/Reservoir
AX280 Dual Radiator
XSPC 1350rpm 140mm Fan x2
140mm Fan Grill (Black) x2
Twin 3mm White LED
5mm White LED
K3 Thermal Paste
Only £169.99 inc VAT.
ORDER NOW
XSPC Raystorm Pro Ion AX360 Watercooling Kit @ £179.99 inc VAT https://www.overclockers.co.uk/xspc-raystorm-pro-ion-ax360-watercooling-kit-wc-40b-xs.html
Kit Contents:
Ion Pump/Reservoir
AX360 Dual Radiator
Twin 3mm White LED
5mm White LED
K3 Thermal Paste
ORDER NOW
Many More Water Cooling Kits Here
- ATX bridging plug
- Intel LGA-775
- Intel LGA-1366
PLEASE NOTE:
ORDER NOW
- ATX bridging plug
- Intel LGA-775
- Intel LGA-1366
PLEASE NOTE:
ORDER NOW
- ATX bridging plug
- Intel LGA-775
- Intel LGA-1366
PLEASE NOTE:
ORDER NOW
- ATX bridging plug
- Intel LGA-775
- Intel LGA-1366
ORDER NOW
- ATX bridging plug
- Intel LGA-775
- Intel LGA-1366
ORDER NOW
- ATX bridging plug
- Intel LGA-775
- Intel LGA-1366
ORDER NOW
- ATX bridging plug
- Intel LGA-775
- Intel LGA-1366
PLEASE NOTE:
ORDER NOW
- ATX bridging plug
- Intel LGA-775
- Intel LGA-1366
PLEASE NOTE:
ORDER NOW
Contents:-
- D5 Vario Pump
- K2 Thermal Paste
Specification:-
ORDER NOW
Contents:-
- D5 Vario Pump
- K2 Thermal Paste
Supports:-
ORDER NOW
Kit Contents:-
- D5 Vario Pump
- K2 Thermal Paste
Supports:-
ORDER NOW
Kit Contents:-
- D5 Vario Pump
- K2 Thermal Paste
Supports:-
ORDER NOW
- ATX bridging plug
- Intel LGA-775
- Intel LGA-1366
ORDER NOW
- atx bridging plug
- intel lga-775
- intel lga-1366
ORDER NOW
- atx bridging plug
- intel lga-775
- intel lga-1366
ORDER NOW
Kit Contents:
Ion Pump/Reservoir
AX240 Dual Radiator
Twin 3mm White LED
5mm White LED
K3 Thermal Paste
ORDER NOW
Kit Contents:
Ion Pump/Reservoir
AX280 Dual Radiator
Twin 3mm White LED
5mm White LED
K3 Thermal Paste
ORDER NOW
Kit Contents:
Ion Pump/Reservoir
AX360 Dual Radiator
Twin 3mm White LED
5mm White LED
K3 Thermal Paste
ORDER NOW
