**WATERCOOLING MADE EASY**
A couple of New Kits by XSPC have been added to the OP.
The new kits have the newly designed CPU block and Reservoir and they make an excellent addition to the current range.
Hi
(i) which would give the better cooling performance?
The EK-KIT P360 (triple, 40mm thick) or the EK-KIT XE240 (double, 64mm thick)
(ii) could either of these radiators take the addition of a GPU into the loop such as the GTX 1070?
I'm planning to get a Phantek Evolv ATX Glass case. Current CPU is i5 2500k but I want the cooler to take me into my next build (or two!)
* I should add that I'm entirely new to watercooling, if I've overlooked a better kit then please give me a recommendation.
Hi
Hi If you wanted just the one radiator the then maybe this kit - https://www.overclockers.co.uk/ek-w...h-performance-watercooling-kit-wc-896-ek.html would be better.
If you are still unsure then I have created this little feature:
https://www.overclockers.co.uk/water-cooling-configurator-wc-144-tl.html
That bascially allows to choose from the most popular components in one place. You you are still unsure you can select the product add them to the basket then post the basket here and I will check it.
Nice new tool.
Thanks, I gave the configurator a go and ended up with a £299 quote, probably with compatibility issues and a 40mm radiator. I think a kit is going to suit me better.
My current thinking is that an EK Blocks X240 kit, with it's 64mm radiator, would handle a cpu and single Pascal or Polaris card.
Hi,
It should have been yesterday so I will check this for you and get back to you.
Edit: Looks they had trouble with the stock and it wont arrive till later next week now.
I like a system that is practically silent at idle would the x360/240 be OK with the pwn controlled ddc pump?
It looks a lot nicer in the pics but I have read a lot of conflicting user accounts of the ddc vs the d5 for noise levels.
Hi, Guys Not updated this page for a while we have had a few new additions to the Water cooling kits that are worth a look at and we currently have some amazing prices on this week only kits. These kits have everything you would need to get you started and even allow for expansion.
XSPC RayStorm Pro Photon D5 AX240 WaterCooling Kit @ £264.95 inc VAT https://www.overclockers.co.uk/xspc-raystorm-pro-photon-d5-ax240-watercooling-kit-wc-40g-xs.html
Supports Intel Sockets: LGA2011, LGA2011-3, LGA1366, LGA1150, LGA1151, LGA1155, LGA1156
Only £264.95 inc VAT.
ORDER NOW
XSPC RayStorm Pro Photon D5 AX280 WaterCooling Kit @ £279.95 inc VAT https://www.overclockers.co.uk/xspc-raystorm-pro-photon-d5-ax280-watercooling-kit-wc-40h-xs.html
Only £279.95 inc VAT.
ORDER NOW
XSPC RayStorm Pro Photon D5 AX360 WaterCooling Kit @ £279.95 inc VAT https://www.overclockers.co.uk/xspc-raystorm-pro-photon-d5-ax360-watercooling-kit-wc-40i-xs.html
ORDER NOW
XSPC RayStorm Pro D5 Bayres RX240 WaterCooling Kit @ £234.95 inc VAT https://www.overclockers.co.uk/xspc-raystorm-pro-d5-bayres-rx240-watercooling-kit-wc-40j-xs.html
Only £234.95 inc VAT.
ORDER NOW
XSPC RayStorm Pro D5 Bayres RX360 WaterCooling Kit @ £254.99 inc VAT https://www.overclockers.co.uk/xspc-raystorm-pro-d5-bayres-rx360-watercooling-kit-wc-40k-xs.html
Only £254.99 inc VAT.
ORDER NOW
XSPC RayStorm Pro D5 Photon RX240 WaterCooling Kit @ £262.99 inc VAT https://www.overclockers.co.uk/xspc-raystorm-pro-d5-photon-rx240-watercooling-kit-wc-40l-xs.html
Only £262.99 inc VAT.
ORDER NOW
XSPC RayStorm Pro D5 Photon RX360 WaterCooling Kit @ £282.95 inc VAT https://www.overclockers.co.uk/xspc-raystorm-pro-d5-photon-rx360-watercooling-kit-wc-40m-xs.html
Only £282.95 inc VAT.
ORDER NOW
We Currently have the following kits on sale so the best time to grab a bargain loop:
EK-KIT L120 (R2.0) Performance Watercooling Kit - Was £179.99 Now £146.99 - View Here
RayStorm 750 AX240 WaterCooling Kit - Was 149.99 Now £141.95 View Here
RayStorm 750 EX360 WaterCooling Kit - Was £134.99 Now £122.99 - View Here
RayStorm D5 EX280 WaterCooling Kit - Was £197.99 Now £182.99 - View Here
RayStorm D5 EX360 WaterCooling Kit - Was £216.95 Now £206.99 - View Here
RayStorm D5 EX420 WaterCooling Kit - Was £227.99 Now £207.95 - View Here
RayStorm D5 RX240 V3 WaterCooling Kit - Was £183.95 Now £165.95 - View Here
RayStorm D5 Photon AX240 WaterCooling Kit - Was £209.99 Now £192.95 - View Here
RayStorm D5 Photon AX360 WaterCooling Kit - Was £227.99 Now £210.95 - View Here
RayStorm DDC EX360 WaterCooling Kit - Was £184.99 Now £162.95 - View Here
RayStorm DDC RX240 V3 WaterCooling Kit - Was £199.99 Now £169.99 - View Here
RayStorm DDC RX360 V3 WaterCooling Kit - Was £209.99 Now £191.99 - View Here
RayStorm Twin D5 AX240 WaterCooling Kit - Was £339.95 Now £328.99 - View Here
RayStorm Twin D5 RX240 V3 WaterCooling Kit - Was £319.99 Now £299.99 - View Here
This Week Only Deals
All Water cooling kits can be viewed here
All water cooling products can be accessed here
