The question is under all this little info if you wana scip ahead
Spec as follows
- 4400X2 @ 2.6 (cooled by scythe ninjar)
- DFI Expert
- Akasa Eclipse Case
Well iv orderd some watercooling parts as follows.
- Silverprop Cyclone Nexus SX chipset waterblock (MM)
- Danger Den CSP-MAG 12 Volt Pump
- Swiftech MCRES-MICRO™ Reservoir
- Black Ice Pro Compact High Peformance Radiator - Black
- Tygon 3603 1/2" ID Clear Tubing
Bascialy I only need to watercool the chipset silly I know but it runs stupidly hot and Iv checked the placment of the zalman heatsink (which is cooled by a fan) and the temps still go above 50C idle.
My aim is to keep the chipset and the PWmic chip cool, leaving my more head room to overclock the 4400 which is perfectly fine on air atm.
SO MY ACTUAL QUESTION!
I have no idea really where I can put the rad.
Iv read your ment to put it at the front of the case if you can, but I cant because of the hard drive cage and cant use the second drive cage because of the size of the scythe.
Could it be mounted on the back fo the case?
Any help on this would be great thanks.
Spec as follows
- DFI Expert
