- 17 Apr 2006
- Hampshire
oceaness said:A computer cannot be silent because electricity make's noise.
However it can be made so you can't hear anything if your sitting a normal distance away from it.
I use Xclio PSU's, using a 700watt and two 750watt, there efficient and have 14cm fans which I can't hear and my hearing is pretty good.
To be honest if you can hear your pump it's either worn down and needs replacing or you've got a naff pump. You really can't hear mine unless you put you ear next to it.
You're just full of helpful information oceaness. Thank you.
That's going in an enclosure for backup purposes shortly though, so all should be quiet again!
