Permabanned
- 6 Aug 2007
Are there any effects of not putting much water into a watercooling system
For example, I'm running a Thermaltake Bigwater 745 system and the resevoir has a "high" and a "low" level indicator, now I have put in coolant so it's JUST under the "low" level indicator so I can actually see the water flowing around the pipes as this is part of the reason I went for watercooling
so is there any negative effects of doing this, it doesnt seem to affect my temperatures even when running orthos dual
thanks
thanks
