I am planning to make a watercooling setup to complement a phase cooled cpu. I am not sure what is the best system to get. The components I'd like cooled are:
GPU
Ram (Koolance ram block)
3 harddrives (2 cooled together, 1 cooled by itself)
chipset
mosfets
Now im only planning at the moment, so im still not sure what my actual hardware will be, i just know that those are the things that need cooling. I have been looking at the Asetek Waterchill Xternal system and the Koolance EVO systems and was wondering if these are any good?
Also I am aware that the mosfets, chipset and ram may slow the flow down. Is this correct? If so is it worth going for a 2 pump setup and using 2 loops, from 1 resevoir to 1 radiator?
I am hoping the Xternal and EVO systems are good as I like the all in one design and the fact that everything is encased and outside the pc case. I would like my radiator to be outside, if going for a custom build pumps etc. can happily go inside the case.
So the question i am asking is:
What is the best setup for me to go for?
Thanks everyone
daven
GPU
chipset
mosfets
Thanks everyone
daven
