- 6 Sep 2016
I have a CM 810 case.
Would a dual 12cm watercooling rad fit directly through the case screw holes?
https://ibb.co/QDtWJqB
https://ibb.co/ft9KTCM
I'm wondering if rad/fan can fit on the lower of the fan holes, will it hit motherboard? Or just go for single rad on the upper fan hole?
Would it be possible to have GPU & CPU cooling? Or just go for CPU?
