- 15 May 2012
- Louth, lincs
Not sure that you really need an additional 240 at the bottom tbh.
need it for when i get gpu waterblocks, the classy's pump out some serious heat, and i have an EVBOT
and besides pete, i cant get monsta's in!!!!
the 240 in the bottom did not fit, need to cut out the bottom 2 pci slots to make it happen also need some very low profile 90's, presuming barbs?? i'm on 16/11 tubing if anyone can suggest anything, i'm using the blood reds.
My suggestion is that you will not be heat limited on the GPUs without a 240 at the bottom. It simply doesn't need it in my rig at all. With modded bioses on my 780s and 1.325V at max overclocks at 1300MHz+ core on both GPUs they are pushing out max 38C in the current hot ambients (in serial). You will not be GPU heat limited (certainly not if you use EK blocks). This is with a 3930 at near enough 5 GHz while benching (max temp 65C again in the hot ambients at 1.4V, all cooled with an AX240 and an AX360).
I ran a 360+240 with SLI 680 Lightnings @ 1.5ish volts and a 3930K at 1.5volts and those rads were more than enough to cope.
Looking good as well Nick![]()
You just want that 3rd rad installed on principle now don't ya?
Will be interesting to see if it really makes a significant difference to your temps.
But damn the inside of your case looks sweet as is.
Where is your PSU?
