Right guys, I'm looking for some opinions on some parts, I'll be doing my first custom loop sometime in the next month'ish and I'm rather confused as what specific parts to get.
I'm looking to get a 360 rad, nothing to thick, I wont be over clocking any time soon so the thinner rads will be most likely ideal for me.
I've been torn between the XSPC EX360 and the Hardware Labs Black Ice Nemesis 360 GTS (possibly adding a second 240 rad in too depending on what happens with my current GPU).
I already have 3 Cooler Master Jet Flo fans 800-2000 RPM (PWM) - 95 CFM ± 10% - 2.72 mmH2O ± 10%
I also have 2 LEPA 600-1600 RPM - Maximum airflow: 63.91 cfm - Maximum air pressure: 2.18 mmH2O - Airflow: 108.65 m³/h, which will be used for the 240 rad if I add my GPU into the mix.
I'm also stuck on which Acrylic tubing to get, while I doubt there is any real difference, anyone have any preference on Primochill or Monsoon 13mm Hardline tubing? I cant decide whether to go Primochill with the revolver fittings or Monsoon with the Hardline fittings which are more secure with the glue on caps.
I'm planning on some form of D5 Pump, either a tube res version or a D5 with pump-top and a separate res. I kind of like the XSPC Acrylic D5 tank but cant find many reviews on it. I'd quite like to do something a bit different and not just go with the bayres/pump combo.
I have a new Corsair 760T due any time now so I'd like to start ordering the parts. I'm planning on getting the XSPC AMD RayStorm CPU block and thats about the only part I have really decided on lol.
