OK guys,
Looking to make a new home for my main system. Going to take great delight in binning an EVGA DG-87 case (easily the worst chassis I've ever dealt with), and probably looking to move into an Enthoo Primo (say 80% sure, unless there is another option soon).
Plan to move over to a custom WC job as I plan to reuse the GPU block, which was hooked up to a Predator 360 before that went bang, and the spare 240 is not up to the job at all.
Was checking out EKWB site for recommendations for a relatively simple CPU/GPU loop, and it was suggesting a EK-CoolStream XE 480 (Quad) mounted in the top which seems a bit unwieldy , as I would assume a dual 360 radiator setup would probably work better overall. Plus there is a thought that a XE rad might have clearance issues with the MB height when mounted in the top (Predator wouldn't fit in the top of the EVGA case for this reason so had to front mount it which really messed up the overall air flow of the case).
Looking through the Enthoo thread is a bit of a mire so wondering if anyone has any suggestions or experiences around putting together a similar build, and might be able to offer some ideas around rads, pump, suitable reservoir size etc (going to keep things relatively simple with soft tubing).
Cheers
Cheers
