WD 320GB SATA, XP says 128GB :/
23 Oct 2002
That London, née Brighton
So i'm installing XP on my new rig, all going well, except it only seems to think my two 320GB disks are 128GB in size. it's an XP-SP1 install, anyone have any clues what could be causing this? A bios setting or some additional driver i need to load pre-windows setup?
Does your BIOS report it as 320GB? If not update that.
If XP install says 120GB on the DOS screens setup I would try using updated SP2 install (installed with XP SP2 slipstream onto 320GB WD no problems)
Ah good call. The bios got the name right, but i didnt check for any physical size attribute. Or, i don't remember checking, in all the excitement at the thing actually booting i was somewhat elated and unfocussed.
As soon as it's done creating the 128GB partition (which i decided it might aswell do, and then i'll see what XP thinks is there when it's installed) i'll go back and check the bios. thanks!
you need windows xp sp1+ to see hds over the size of 137gig
i good tip for u is if u got a pc with windowx xp and sp1+ installed plugin the hd and format it then use it in your system
if you aint got another pc use a m8s :)
