WD 36Gb Raptor desirability??
3 Aug 2006
Are these drives still worth having?
I was considering flogging these and getting a pair of 80Gb SATA2 disks, but not sure how they would stack up performance wise.
I have 2 of them running RAID-0 running my OS, and I would replace those with the 2 x 80's also in RAID (but going from SATA1-2 obviously)
What do you think chaps?
I think that the older 36gig models were awful iirc, though the newer ones were ok.
I think that a lot of people here have 2 75gig raptors if in a raid setup.
My buddie has 2 of those raptors.
He's just upgraded to conroe, and the performance is different now.
You can see his results here.
The new -ADFD versions (SATAII, 16MB, NCQ) are definitely worthwhile, but I'm not so sure about the -GD version. As far as I remember, the WD360GD isn't that much faster than the latest 7.2krpm drives, whereas the WD360ADFD is the same speed as the WD1500ADFD, the fastest drive currently available for desktop environments.
Mine will be the -GD... Better flog them then :D
easyrider said:
The 36 gtig raptors were slower and noisier than the 74 GB counterparts.
The 150 gig raptor is in a league of its own.
True for WD360GD and WD740GD, but by all accounts, the newer WD360ADFD and WD740ADFD are exactly the same speed as (and slightly faster in some other tests than) the WD1500ADFD.
Hm, the speed that he gets is day and night difference with the one posted in a different thread. Do Conroe make so much difference?
