I've upgraded the child's PC for Christmas and have put an existing WD 3D NAND 1TB M.2" drive into the Z490F Strix board along with his existing SSD. The board recognises the 2.5" SSD but not the M.2. After some investigation we have changed the SATA port that the SSD is plugged into as apparently this can cause a problem. The M.2 drive is still not being recognised.
I understood that a NAND drive was a different type of Flash memory but it has worked fine in my son's old PC so I'm a bit stumped. If anyone can point us in the right direction it would be appreciated as I'm becoming confused at all the different drive connections. SATA to me is a connector and M.2 is a different connector. The differences between NAND and NVMe are beyond me unfortunately.
