I am having an OCD dilemma, bought a WD40EZRZ-00GXCB0 with serial WCC7K2HR9Fxx (2 last serial digits not included because of warranty) made on 27 FEB 2020
It's new and I still don't want to open it, because if there is a chance it's SMR I can sell it if it's new and I don't want it.
So this SHOULD be CMR since its "EZRZ" and everybody knows that "EZRZ" are CMR and "EZAZ" are SMR in this instance:
https://nascompares.com/answer/list-of-wd-cmr-and-smr-hard-drives-hdd/
https://hddscan.com/blog/2020/hdd-wd-smr.html
But...what makes me suspicions are the following internet threads, first this reddit post:
https://www.reddit.com/r/zfs/comments/g4fmjl/is_wd_blue_4_tb_smr_or_dmr_anyone_know/
Where somebody claims the difference between two models of WD Blue which are "EZRZ":
WD40EZRZ-00WN9B0 - Giant (C4E in serial number) - 8 heads, PMR
WD40EZRZ-00GXCB0 - APOLLO (С7K in serial number) 6 heads, SMR.
Of course this just might be a mistake, I tracked the original post and it came from Russian forum, so I was searching further and found this website too:
https://electroanswers.com/technolo...#How_do_I_know_if_my_hard_drive_is_SMR_or_CMR
With the claim:
WD40EZRZ-00GXCB0 – APOLLO (С7K in serial number) 6 heads, SMR.
BUT on their list here:
https://www.truenas.com/community/resources/list-of-known-smr-drives.141/
It is not present as SMR.
Then there is a topic from a random member on Linus with the same dilemma:
https://linustechtips.com/status/295061/
And the member assumes that this should be CMR HDD since he has both models of WD Blue and they both have 64mb of cache.
Should I open it, check it with HDD Sentinel for cache size and if it's 64mb, it should be CMR 100% right? Or is this one an isolated case where WD made SMR HDD with 64mb, is that even possible? IS it possible to test it somehow to be 100% sure?
Anyway, I would appreciate if somebody has the same HDD or want to make a philosophical debate out of this case or somebody with extreme knowledge who can shed some light on this dark and tough issue
With the claim:
