WD Caviar blacks
23 Nov 2005
Kingdom Of Fife
I have two of these 640GB drives in RAID0. Should I enable write back cache? Get a huge performance increase by enabling caching, as more data is temporary stored before it is written/read from the HDD. I know RAID0 is dangerous enough!, so with WBC enabled I could be one bad shutdown from disaster? Anyone with any thoughts? I've turned it back off in the meantime!
I've been running RAID0 with caching enabled for years and haven't had any problems after unexepected shutdowns. At the end of the day the worst that happens is you have to restore from backups.
I have exactly the same set-up as you but i have never looked at the different opitions etc
how noisy do you find the drives under seek. Mines are rediculously noisy and they are bungy modded:(
Very quiet!, can not here them at all. Only niosy drive is my Deskstar I use to back up my images to, Acronis is my friend, a great program!
Thanks for the input guys!, Write cache enabled it is then!
