Hi,
One thing that has always puzzled me with HDD pricing - why is it that often buying an external drive is cheaper that buying an internal drive, even though the external model uses same drive and has the extra expense of the case etc?
For instance :-
https://www.overclockers.co.uk/wd-4...e-internal-hard-drive-wd40ezrz-hd-415-wd.html
This is the same drive as used by this :-
https://www.overclockers.co.uk/wd-e...ernal-hard-drive-wdbwlg0040hbk-hd-421-wd.html
I've bought the external one before, and on dismantling it has the same drive. I appreciate that taking the external unit apart invalidates warranty, but just discussing price difference here.
On a side note, using the drive from the external unit internally and it shows in an odd 2 to 3 partition setup and data in unreadable. Similarly, moving a formatted drive into the external box and it requires reinitialising/reformatting to work. Seems the controller board is doing some odd things...
For instance :-
