WD MyBook 2 Pin plug Normal?
7 Nov 2009
the other day i ordered a WD MyBook 2TB USB 2.0 ext hdd
it came today and when i opened it to my surprise it was a 2 pin plug?
i believe these are a lot more for use in the EU rather than UK? I dont even have a adapter to fix it...
i dont really feel like using an adapter all the time, but if i order one from another place (ie ocUK) am i going to get the same thing?
cheers
Looks like you got the EU / US model instead of the UK model.
It should come with a UK plug unless specified otherwise. Let the seller of this item know.
