WD NetCenter
Permabanned
18 Oct 2002
Does the Western Digital NetCentre have to be physically connected to a router or can it be placed anywhere in the house?
It has a wired ethernet connection therefore to access it it has to be connected into your local LAN which in most cases means your router. It can be placed anywhere in the home but you'll have to trail a cable to it.
noob said:
The only differences I can see if the MyBook is Gigabit and the NetCentre isn't and the NetCentre acts as a print server. Is that correct?
That's how I read it, yes.
noob said:
Cheers. I don't know whether to wait for this: -
It depends what your requirements are. Do you have a printer you want to share?
I was going to get a MyBook World but then realised it had a fan, and i've heard the fan in the other MyBook models is noisy. Therefore I ordered a NetCentre 500gb (for £160 from elsewhere) as they have no fans due to the side ventilation slots.
Nick
Nick
When the drive spins down and the heat subsides, does the fan not spin down aswell?
I have no idea... but a drive without any fan at all appeals to me more than one with a fan that may keep spinning up/down or stay on permanently. :)
Also, I'm not sure if the MyBook is Mac compatible - I think it uses its own proprietary protocols. The NetCentre just uses normal SMB shares.
Nick
The GigE think is a waste of time, there is no way any single disc is going to push anywhere near 1000Mbps, probably peak at about 85Mbps.
HEADRAT
