I received a Western Digital Caviar SE16 250GB 2500KS SATA-II 16MB Cache - OEM (HD-046-WD) from OCUK this morning and I'm having a problem with it. It's the main HD on a new system I've built, but it's only showing 127GB available. Now I know the amount of actual space on the drive is always a bit less than advertised, but from 250gb to 127gb is a bit much. I thought I might have been shipped the wrong drive, so I removed the drive and checked the label.
WD Caviar SE16
Serial ATA Hard Drive
Drive Parameters: LBA 488397168 250.0GB
WD P/N: WD2500KS - 00MJB0
Can anyone tell me why I'm only getting 127GB from this drive?
*EDIT* I've checked the drive info on the system again and it looks like it's the correct drive, so I'm guessing it's something to do with the sata drivers. I didn't use a sata driver disk at windows setup because it detected the drive. The MB installation CD gives the option of making a Silicon Image 32bit sata driver disk or a ULi 32bit/64bit SATA driver disk. Does anyone know which of these I should use at windows setup?
WD Caviar SE16
