Have just been reading up on the WD10EARS advanced format and also how you need to use the WD align partition utility and / or jumper 7-8 when using XP.
Does anyone know if you have to do this if just using the drive in an external caddy enclosure? Does the above apply only if you plan to install / boot Windows XP?
Cheers.
Cheers.
