weak ports on ssd?
26 Aug 2004
South Wales
I recently got a 256gb Samsung ssd, when i plugged both cables in and went to put it in my case i noticed only a bit of movement was making the drive make a click noise, so i figure the end connections of the ssd are a bit weak to do this under only slight pressure of the cables?. it's as if something was bending and causing the click.
Will this cause any problems?, or has anyone else had this?.. my last ssd did not do this.
