Weak washer jets.....
It improved a bit when I ran isopropyl achohol through the jet part of it. Might chuck some of that into the tank when it's empty and see how it goes.
Just fit new jets.
I had an older Merc in for MOT last week (with that style of jet) which I failed for not providing sufficient fluid to clear the windscreen ,and no amount of trying to clean the jets worked, so fitted new ones and it passed.
Had same problem on wife's car.
I crammed a flexible hose pipe to the down the filler tube to the bottom of the tank to blast the gunk and blew backwards thru the pipe into the tank. There was so much sludge in the bottom. I ran the hose for 5-10 mins with the gunk overflowing out, couldn't believe how much there was
Plus 1 for new jets.
I had some intermittent issues earlier in the year. Sometimes fine sometimes almost nothing. After lots of faffing I just replaced them. They weren't expensive, it was a punt as I was convinced the old ones had been cleared.
But I was wrong, the new ones have been great and it walked it's MOT. I knew if i didn't sort it, that would be the day they wouldn't work!
mercedes jets he'd pictured, from their size (and absence elsewhere on line) had looked like they incorporated one way valves,
which are the liability with rubber washer inside - bmw had had separate valves and with fine wire could clean the nozzle reliably.
nozzles - the oem audi ones have adjustable direction £10/ea, but chinese versions apparently can be unadjustable - so maybe washing car behind.
(stupid audi rear washer had a 3" 4/5mm metal tube through wiper spindle supplying nozzle with a small supply hole at it's base I only found/unblocked after dissesembly.)
thanks for reminding me, i need to check out an underpowered jet on the left hand side of the 4 series
right is fine but left one comes out but low powered. Not investigated yet
I've had issues in the past with really cheap washer fluid blocking jets. It seemed to break down into little clots/clumps which blocked the jets.
I've stuck to Halfords concentrate and it's been fine since.
So to update the thread in case anyone one else stumbles upon it.....
It had improved enough by November that it was not mentioned on the MOT. I had been running it with pretty much pure winter strength screen wash.
I have continued to use proper screen wash and not diluted as much as suggested. I'd say it's possibly as good as it's ever been now.
Conclusion, the tank/filter/ jets had become partially gummed up by using the wrong type of product.
Noticed mine getting a bit weaker, by proper I assume you mean branded?
Any brand in particular?
I've used a couple of brands, the latest being Prestone but that smells horrible (I usually like the smell of screen wash :D)
Really, I just think you need to use fluid that's specifically made for the purpose. I have been guilty of using a weak soap solution in the past, particularly in the summer months.
In thirty plus years of driving it's not caused a problem, until now. Just goes to show you never stop learning :eek:
