Permabanned
I was always under the impression that Wordpress was really aimed at people wanting to make blog sites as apposed to actual dynamic web pages.
You can do a lot with it. You also learn to rely on it - which isn't useful.
Don't worry if you can't design for toffee. Most Web Designers are pretty crap designers anyhow.
Most 'Web Designers' that are actually 'Web Developers' can't design for toffee - yep. It's ridiculous to say most 'Web Designers' are pretty crap designers, it's just ignorant and silly.
Most places will function with a Designer that is a designer foremost perhaps with some basic HTML/CSS skills and then a Developer to do the rest.
You need to have a good knowledge of design to be able to design a website well, having the ability to code and create a website doesn't mean you are a good web 'designer'.
A solid foundation in design is needed, and I bet most 'Web Designers' out there that are any good have 'Graphic Design Degrees/Principles/Basis/Training/Self-Taught/Whatever.'
One thing that was unclear in your post is weather you want to get into web development OR web design. It sounds like you want to learn how to build websites not so much learn about interface and web design.
If it is web development (building) your interested in it seems there is sound advice given here. Just make sure you learn the right way (abiding to W3C standards) at the start, rather than learning it the wrong way first and having to re-learn the code later.
Hey dude , how you getting on?
I think I'm about ready to start work proper on my website although I'm still trying to iron out some details. I'm not very good at the design aspect so I'm considering using a simple psd design and turning it into html/css. I'm still learning about html/css but I will probably start digging into javascript shortly.
How about you? I see you've added some new stuff to your site; do you have any more plans?
I've started using Sublime Text 2 (beta) and it put's notepad++ to shame. I can't recommend it enough.
But a licence for Sublime 2 is $59 and notepad++ is free, is it really that good, i doubt it's worth paying for over n++ for someone starting out.
Notepad++ has the ability to do the same. I can't remember if its a plugin supplied with the installer or if you have to download it but it does have that ability.What I have found nice about using the code editor in MS Expression Web is that when you type an element say <p> it automatically adds the close </p> to it so when you type it fills inbetween
