webcam over rj45 cable
1 May 2007
hi
is it possible to run a usb webcam over 60metres of rj45 to a pc to use as a home cctv cheap setup.
It would be a the webcam into a dongle sort of thing usb to rj45 then the 60 metres, then the signal converted into usb back from the rj45 to the pc.
cheers
nigel
If you are using USB <-> CAT5/6 converters then there is no reason why, subject to the converters allowing that length Cat5/6, this wouldn't work.
If the converters supply the standard CAT5 signal range/voltage, then it should be good up to about 90m - but have you looked at native CAT5 cameras? Pricier, but a much, much nicer solution IME.
