Weekend Memory Roundup - Deals & New Products
15 Feb 2006
Staffordshire
Hi folks.
Here are our latest memory deals for the weekend and also a round up of hot new products ;)
Click HERE for the 'Deals & Hot New Products' Page.
DDR 3 Triple Channel:
Kingston HyperX 6GB (3 X 2GB) Intel XMP DDR3 2000MHz CL8 Triple Channel Kit @ £310.98 Inc VAT.
Kingston's KHX16000D6K3/6GX is a triple-channel kit of three 128M x 64-bit 1GB (1024MB) DDR3-2000 CL8 SDRAM (Synchronous DRAM) memory modules, based on eight 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Each module kit has been tested to run at DDR3- 2000MHz at a latency timing of 8-8-8 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333Mhz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V. The JEDEC standard electrical and mechanical specifications are as follows:
- JEDEC standard 1.5V ± 0.075V Power Supply
- VDDQ = 1.5V ± 0.075V
- 667MHz fCK for 1333Mb/sec/pin
- 8 independent internal bank
- Programmable CAS Latency: 6,7,8,9
- Posted CAS 8-8-8
- Programmable Additive Latency: 0, CL - 2, or CL - 1 clock
- Programmable CAS Write Latency(CWL) = 9(DDR3-1333)
- 8-bit pre-fetch
- Burst Length: 8 (Interleave without any limit, sequential with starting address “000” only), 4 with tCCD = 4 which does not allow seamless read or write [either on the fly using A12 or MRS]
- Bi-directional Differential Data Strobe
- Internal(self) calibration : Internal self calibration through ZQ pin (RZQ : 240 ohm ± 1%)
- On Die Termination using ODT pin
- Average Refresh Period 7.8us at lower then TCASE 85°C, 3.9us at 85°C < TCASE . 95°C
- Asynchronous Reset
- PCB : Height 1.180” (30.00mm), single sided component
OcUK Review HERE.
Buy Now @ Just £310.98 Inc VAT.
Kingston HyperX 3GB (3 X 1GB) Intel XMP DDR3 2000MHz CL9 Triple Channel Kit @ just £154.09 Inc VAT.
Kingston’s new HyperX® T1 series features heat spreaders with HTX (HyperX Thermal Xchange) Technology that makes them literally the coolest for any new rig you may be building.
These high-performance modules are designed with heavy aluminum extrusions with extended fins and other component technology to keep DRAMs cool and modules ready for performance, gaming and overclocking.
You’ll get chills when you use these new modules at your next LAN party or online shoot out.
Kingston's KHX16000D3T1K3/3GX is a triple-channel kit of three 128M x 64-bit 1GB (1024MB) DDR3-2000 CL9 SDRAM (Synchronous DRAM) memory modules, based on eight 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Each module kit has been tested to run at DDR3- 2000MHz at a latency timing of 9-9-9 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333Mhz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V. The JEDEC standard electrical and mechanical specifications are as follows:
- Programmable CAS Latency: 9-9-9-24 @ 1T
- Posted CAS
- 8-bit pre-fetch
Buy Now @ Just £154.09 Inc VAT
Patriot Viper 6GB (3 X 2GB) DDR3 PC3-12800 (1600MHz) Low Latency (8-8-8-24) Tri-Channel kit @ Just £88.99 Inc VAT.
Patriot Extreme Performance (EP) Low Latency line is engineered to expand your gaming options. These modules are designed to operate at 1600MHz at 8-8-8-24 timings. Equipped with Patriot ACC (Aluminum Copper Composite) technology, these modules are designed for maximum performance and stability under extreme overclocking conditions. Engineered with quality and Performance in mind, Patriot Extreme Performance line is the ultimate solution for extreme overclockers, gamers, and PC enthusiasts.
- Extreme Performance PC3-12800 (1600MHz)
- Low Latency (8-8-8-24)
- 1.65V
- Equipped Patriot Viper Heat Shields with integrated ACC (Aluminum Copper Composite) technology
- Lifetime Warranty
- XMP Ready for Core i7 Processors
OcUK Review HERE.
Buy Now @ Just £88.99 Inc VAT.
Kingston HyperX 6GB (3 X 2GB) Intel XMP DDR3 12800C9 1600MHz Tri-Channel Kit Just £89.99 Inc VAT.
- Programmable CAS Latency: 9-9-9-27 @ 1T
- Posted CAS
- 8-bit pre-fetch
OcUK Review HERE.
Buy Now @ Just £89.99 Inc VAT.
OCZ Blade Series 6GB (3 X 2GB) DDR3 PC3-16000 Triple Channel @ £369.99 Inc VAT.
The Blade Series Triple Channel Memory kit is the latest maximum-performance RAM designed specifically for the Intel® Core™ i7 processor / Intel® X58 Express Chipset. At DDR3-2000, CL 7-8-7, the Blade Series harnesses industry-leading speeds at the low voltage required to safely run Core i7’s triple channel mode. With the ideal combination of all the factors that formulate the ultimate memory solution— density, speed, latency, and an effective new cooling design—the Blade Series is guaranteed to please enthusiasts looking to take the hottest Intel platform to new heights. The Blade heatspreader aims to enhance heat dissipation to improve the longevity and stability of the modules while keeping a sleek, low profile. The new propriety design has numerous channels that increase the surface area to more efficiently offload heat away from the memory chips and PCB. Push your gaming or overclocking rig to the extreme with the superior thermal solution and unmatched speeds of the high-end Blade Series memory modules. Wheter seeking maximum frame rates in the latest PC titles or yearning for the highest benchmark record, the Blade Series was developed for gamers and overclockers looking to make the most of their high-performance systems.
- 2000MHz DDR3
- CL 7-8-7-20
- Available in 6GB (3x2048) Triple Channel Optimized Kits
- Unbuffered
- 1.65 Volts
- 240 Pin DIMM
- Pure Aluminum Heatsink
- OCZ Lifetime Warranty
OcUK Review HERE.
Buy Now @ £369.99 Inc VAT.
OCZ Reaper 6GB (3 X 2GB) DDR3 PC3-14400 (1800MHz) Tri-Channel @ Just £113.99 Inc VAT.
The OCZ Reaper HPC PC3-14400 triple-channel memory kits are designed specifically for the Intel Core i7 processor / Intel® X58 Express Chipset. Optimized for the Core i7’s triple channel mode, these new 6GB kits ensure optimal performance via an ideal combination of low voltage requirements, speed, and latency. The Reaper HPC Series makes use of an innovative cooling solution to more effectively dissipate heat produced by high-speed memory, and offers superior cooling technology to ensure superior stability and performance over the entire life of the memory. The thermo-conductive copper heat pipe conduit is ideal for overclocking where every degree matters, ensuring that your cutting-edge investment will maintain its integrity throughout the toughest gaming missions, overclocking, or intense program applications. Developed for enthusiasts and early-adopters, the low voltage OCZ Triple Channel solutions are the choice counterparts for leading-edge performance that won’t inhibit the functionality of Core i7 CPUs. In addition, modules are tested in matched triplets ensuring superior compatibility. OCZ’s Triple Channel kits are 100% hand-tested for quality assurance and compatibility and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory module is backed by the industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1800MHz DDR3
- CL 8-8-8-26 (CAS-TRCD-TRP-TRAS)
- 6GB Triple Channel Optimized
- Reaper HPC Heatspreader
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
Buy Now @ Just £113.99 Inc VAT.
OCZ Gold 6GB DDR3 2000MHz PC3-16000C10 Low-Voltage Triple Channel Kit @ Just £104.99 Inc VAT.
***Currently the cheapest 6GB 2000MHz Kit in the UK***
The OCZ PC3-10666 triple-channel memory kit is designed specifically for the Intel Core i7 processor / Intel X58 Express Chipset. Optimized for the Core i7’s triple channel mode, these new 6GB kits ensure optimal performance via an ideal combination of low voltage requirements, speed, and latency. Developed for enthusiasts and early-adopters, the low voltage OCZ Triple Channel solutions are the choice counterparts for leading-edge performance that won’t inhibit the functionality of Core i7 CPUs. In addition, modules are tested in matched triplets ensuring superior compatibility. OCZ’s Triple Channel kits are 100% hand-tested for quality assurance and compatibility and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory module is backed by the industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 2000MHz DDR3
- CL 10-10-10-20 (CAS-TRCD-TRP-TRAS)
- Gold Z3 XTC Heatspreader
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
Buy Now @ Just £104.99 Inc VAT.
Corsair XMS3 6GB (3 X 2GB) DDR3 PC3-12800C8 (1600MHz) Tri-Channel Kit @ Just £97.99 Inc VAT.
Corsair's value for performance 6GB 1600MHz CAS Latency 8 memory kit solution for the Intel Core i7 processor.
The XMS Series TR3X6G1600C8 G is a 6144MByte kit of DDR3 SDRAM DIMMs built using Corsair’s new high performance heat sink. This part delivers outstanding performance in the latest generation of X58 DDR3-based motherboards. It has been tested extensively in popular X58 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 1600MHz at latencies of 8-8-8-24 at 1.65V VDIMM.
- New XMS3 Heat Spreader
- Matched Triple Kit
- 1600MHz
- 8-8-8-24
- 1.65V
- Lifetime Warranty
OcUK Review HERE.
Buy Now @ Just £97.99 Inc VAT.
Kingston HyperX 4GB (2 X 2GB) DDR2 8500C5 1066MHz Dual Channel Kit @ Just £42.99 Inc VAT.
Kingston's KHX8500D2K2/4G is a kit of two 256M x 64-bit 2GB (2048MB) DDR2-1066 CL5 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR2 FBGA components per module. Total kit capacity is 4GB (4096MB). Each module pair has been tested to run at DDR2- 1066MHz at a latency timing of 5-5-5-15 at 2.2V. The SPD is programmed to JEDEC standard latency 800Mhz timing of 5-5-5-18 at 1.8V. Each 240-pin DIMM uses gold contact fingers and requires +1.8V.
Exclusive Premium Priority Lifetime Warranty.
The electrical and mechanical specifications are as follows:
- Power supply : Vdd: 1.8V ± 0.1V, Vddq: 1.8V ± 0.1V
- Double-data-rate architecture; two data transfers per clock cycle
- Bidirectional data strobe(DQS)
- Differential clock inputs(CK and CK)
- DLL aligns DQ and DQS transition with CK transition
- Programmable Read latency 5 (clock)
- Burst Length: 4, 8 (Interleave/nibble sequential)
- Programmable Burst type (sequential & interleave)
- Timing Reference: 5-5-5-18 at +1.8V / 5-5-5-15 at +2.2V
- Edge aligned data output, center aligned data input
- Auto & Self refresh, 7.8us refresh interval (8K/64ms refresh)
- Serial presence detect with EEPROM
- High Performance Heat Spreader
- PCB : Height 1.180” (30.00mm), double sided component
Buy Now @ Just £42.99 Inc VAT.
Corsair XMS2 4GB DDR2 PC2-8500C5 TwinX (2x2GB) Dual Channel Kit @ Just £39.99 Inc VAT.
The Twin2X4096-8500C5 is a 4096 MByte matched pair of DDR2 SDRAM DIMMs. This part delivers outstanding performance in the latest generation of dual-channel DDR2-based motherboards. It has been tested extensively in multiple DDR2 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 1066MHz at latencies of 5-5-5-15.
- 1066MHz
- 5-5-5-15 Timings
- EPP Profile
- 2.1V
Buy Now @ Just £39.99 Inc VAT.
OCZ Platinum Revision 2 XTC 2GB (2x1GB) PC2-6400C4 Dual Channel Series DDR2 @ Just £19.99 Inc VAT.
OCZ PC2-6400 Platinum Revision 2 is the latest version of the Platinum DDR2-800 Series. The PC2-6400 Platinum Rev. 2 has been re-engineered to turn out heart-pounding 4-4-4 timings with flawless performance and stability and offer lower latencies than standard 800MHz DDR2 memory.
OCZ exclusively developed these modules for the extreme gamer and overclocker to give high-end DDR2 based systems that extra performance edge that is demanded by today’s hard core gamers and enthusiasts.
The new OCZ PC2-6400 Platinum Rev. 2 utilizes the latest OCZ heatspreader design. XTC (Xtreme Thermal Convection) Heatspreaders allow increased ventilation and heat dissipation due to an innovative honeycomb design providing more direct access to the actual memory ICs.
As part of the award winning OCZ Platinum DDR2 series, the PC2-6400 Platinum Rev. 2 is built with leading edge technology designed and qualified with special selection of premium components to maximize performance in even the most demanding computing environments. OCZ PC2-6400 products are 100% hand-tested to ensure compliance with stringent quality standards. In addition, each member of the OCZ Platinum family is backed by an industry-leading lifetime warranty, toll-free technical support and the exclusive EVP (Extended Voltage Protection) coverage.
With its ultra-fast performance, high quality and reliability, the OCZ PC2-6400 Platinum Revision 2 edition is a perfect memory upgrade for the latest CPU arrivials.
- 800MHz DDR2
- CL 4-4-4-15 (CAS-TRCD-TRP-TRAS)
- Platinum Mirrored XTC* Heatspreader
- 1.9-2.0 Volts
- 240 Pin DIMM
- OCZ Enhanced Latency Technology
- 2.2V EVP**
***Previously sold for £29.99+VAT***
Buy Now @ Just £19.99 Inc VAT.
Drop the dual channel ddr3 prices!! argh! Would the Patriot "viper" 2000mhz DDR3 dual channel kit work OK in my striker II extreme?
EDIT - found out it does, but Nb needs to be around 1.6v, which is an impossibility for me without water. :(
Hi M8. Been a while since we talked Striker II :D
Get some water on it or one of these:
http://www.overclockers.co.uk/showproduct.php?prodid=SY-000-AN&groupid=701&catid=57&subcat=399
Helped with mine before I watercooled the NB.
Just for reference, the Patriot is fully certified and designed for Nforce 790i SLI chipset ;)
Hey mate,
I did get one, but it doesn't do much unfortunately. I still get NB temps into the low 60s with 1.52NB volts. I bought a Delta 60mm and that lowered temps down to 50, but the noise it makes is totally unbearable.
Also, I notice you've only got 1 kit left. Will you be getting more in? If I do sort out my cooling, I would be getting a kit around late May time.
More on order m8 ;)
A couple of these prices are the same as they were before the weekend. The rest are all either new pricing or brand new lines just arrived into stock. The idea here is to give everyone easy access to the latest deals and hot new products in one thread. There are some reviews in there too. Also, the link at the top will take you to one webpage on the OcUK site with all of the above products in one place. ;) Enjoy :)
Another quick q for you here then. I've got 4 modules of 1333 corsair in at the moment with a dominator airflow fan on them. If I got the Vipers, I'd have to take off the corsair fan, in order to get the spotcool over a part of the NB fusion block.
Would the patriot vipers need cooling? or would a little draught from the spot cool be sufficient?
The Patriot Heatsinks are an alluminium/ copper hybrid. We clocked the nuts off them in our tech dept and they ran sweet as a nut with no extra cooling ;)
That's cool. Also, what tubing did you use with the board? Did you use the 3/8 stuff that came with the mobo? I read that the supplied fittings are prone to leaks.
The "Reviews" , is there any reason the charts DONT show other intel chipset / memory results , only amd systems Vs the currently reviewed system ?
The memory is tested at its rated speed to show how it performs out of the box - if you tweak it you know to expect faster results.
The sandra screen is to show the bandwidth of each kit.
We didnt have time to bench any games/apps as i did it whilst working.
If you compare the sandra screens to eachother then its all good.
