a little bit of weight wouldnt make that much difference tbh.
Okay, so eating at maintenance and eating adequate protein (200g) should be enough to still see me make gains?
Stop mixing it up. Aim to do your working sets at 1 weight. If you do all your reps at that weight then the next session put the weights up.
See how that goes for a few weeks.
I don't think you are benching too much personally, you aren't having an intense workout every session, just 1 working exercise.
If after a few weeks you are still stalling then it might be worth looking at a more specific routine![]()
That might just be your opinion, but it doesn't make any sense. I'm certainly of the opinion that there is no one right way of doing things, but there a certainly wrong ways.This is just my opinion so no flaming, everyone trains differently right?
Train your chest using the bar one week, make sure to hit flat, incline and decline, this is going to put stress on all the muscle fibers in the chest rather than just flat and some incline at the end which i see most people do.
The next week use dumbbells with flat, incline and decline.
On shoulders I do the same using an Olympic bar then the next week switching to dumbbells.
I don't know how you could possibly fit both in one week without burning out. Which in return would lower your maximum lift.
Same as legs, I squat one week, then machine press the next. Dead lift one week then pullups and machines the other week.
Wow, you clearly are an elitist and only your way is correct bro!
No, diet is absolutely not going to be the limiting factor in that kind of stall on a linear progression. Adding 5% in a week is a lot if you're at your limit; you wouldn't be suggesting that the only reason that the strongest guys can't add 5% every week is their diet, would you?
Deload by 20%, look at your form and work back up.
