mug2k said:No luck underclocking from the nvdia taskbar just says failed when I test it.
Current Settings :-
Core Clock Frequency - 300Mhz
Memory Clock Frequency - 1.4Ghz ()
The artifacts or whatever first appear on the load saved game screen the text on each letter has little chunks missing.
Looks like its ****** imo !
Cyber-Mav said:hold on, a 6800le should have its ram running at 700mhz (350mhz ddr). im sure someone will have clocked on to this rightnow and will post you the fix.
looks like your ram is overclocked silly high.
