Weird graphics card glitches
  • Thread starter Thread starter Pho
  • Start date Start date
Pho
Pho
18 Oct 2002
Derbyshire
I'm having some issues with my GPU. It's a 780 GTX so getting a bit long in the tooth but I don't want to upgrade until the nVidia 3XXX range comes out.
Notice all the green/blue/teal/aqua or whatever they are pixels and how in the colour pallet at the top right there's a green curve that shouldn't be there.
If I adjust the current hue the green line moves smoothly :confused: - https://photos.app.goo.gl/ejvY541Ngy2estiE8
If I take a screenshot and send it to someone it looks perfectly fine to them. If I take a screenshot and open the image up in Photoshop I see the odd pixels still. But what's really weird is that if I move the image around or resize the image, the weird pixels move with the image, and if I use a colour picker I can see from the RGB colour code that that pixel really is the colour that I'm seeing on my monitor. It's like there's some filter being applied to my graphics that's physically embedding this in the image.
Here's what it looks like in a game:
https://photos.app.goo.gl/regZLaQqiCFKG5zF8
(oh and if you play COD, yes that is the secret bunker Mud Drauber unlock ;))
If I reinstall the nVidia drivers it seems to go away but may randomly come back again a day or two later.
Motherboard: MSI B450 Gaming Carbon AC
CPU: Ryzen 3700X
OS: Windows 10 2004 update
I do randomly get hard resets every so often, this has only happened since upgrading to the above bits and pretty much always when gaming or playing video. No crash dump, just a reboot.
I'm really confused, especially with the fact it's not just corrupting static parts of the screen.
Cheers
what psu do you have, and your ram too?, just noticed the gpu :)
you mention windows 10 update 2004, is that an insider build as i don't have that only version 1909 on my end (build 18363.836), regarding the gpu it could be on its last legs, try disabling AA in game's and run at medium settings to see if the artifacting goes away.
I did play with overclocking the GPU a couple of months back, both its core and memory and voltage. Wonder if that didn't help? I did end up undoing it though and the temperatures were never over 70c or something so shouldn't have been stressing it too much.
I'm not 100% sure on the wattage but I think it's an OCZ gamexstream 700w. I was using this on my old machine, which was a overclocked 2500K and would have been far more power hungry - I only swapped the motherboard/CPU/RAM and added an NVME. The RAM is Thermaltake Toughram RGB running at 1.35v/3600Mhz as specified.
2004 is the April 2020 update that's being rolled out now. You can install it before it hits your Windows update by clicking update on here.
Thinking about it, I think the greenness problem did start after installing this version. However the crashes have been happening for a while, but I think this version has made it more stable from that point of view.
My motherboard has an 8+4 pin CPU connector, I do only have the 8 pin connected as I didn't have a connector for the 4 in but from what I read the 4 pin is only needed if you're doing extreme overclocking which I'm not and lots are running it without.
thats a very old psu, found a review from 2006 online, have you got any monitoring programs installed like hwinfo64 or hwmoniter?, or when you restart head into the bios and check the voltages the psu is supplying, the programs i mentioned just will do the same thing. you need to put the pc under load and have one of the programs above running to show what the psu is outputting, if you get stuck post a screen shot here and we'll take a look and make sure everything's good :)
the extra 4pin eps next to the 8pin on the board is only needed if your overclocking the cpu hard, tbh if you were the 8 pin cable is more than enough anyway, so no issues there.
i suspect your psu maybe the problem, if your old system was playing up before your upgrade could be further evidence that the psu is on the way out, may have already damaged the gpu too
Oh I just checked, I think that was my previous one :o. The one I have now is an OCZ ZS 650w, but even that looks like it was released in 2011. Didn't realise it was that old! My old system was rock solid.
I have a couple of other PSUs hanging around so I might give one of those a try too.
I'll give HWInfo a go and see what it reports thanks for the suggestion. Hopefully(!) it'll crash again and we can figure it out.
I thought the olde rule was that if you took a screenshot, 'mailed it and everything was fine, but it was broken on your own screen, then it meant it was the monitor, or the cable. Though, that wouldn't explain why it moves :confused: unless it's only the rendering part of the card that's broken, not the generation. Though, it fixing if you reinstall drivers suggests that it is either a software issue, or a fault that the drivers re-calibrating corrects, which could also be the monitor, or the cable.
The hard resets may or may not be related.
I guess a compatibility issue between the motherboard and the GPU is possible, since one is much older than the other. Have you tried different drivers for the graphics card and the chipset? Though that still wouldn't explain the resets.
I'd be tempted to try using a different monitor cable, or using a different type of port hdmi/display port/VGA etc. Then try connecting to a TV or other monitor all see if it goes away. But looks like it could be the card.
Managed to capture a log. I I guess it lost a few seconds before the crash due to it not being written to disk.. if you have any ideas that would be great. I'm a bit out of touch as to what voltages are good/bad in PCs now
https://www.dropbox.com/s/aa95k25630zb7t1/log.zip?dl=1
Yep exactly. It's almost as if it's in a green screen mode or something. Utterly confused :D.
I'm running the latest nVidia drivers but it might be a good idea to roll it back a couple actually and see, good suggestion.
Ah good suggestion, I have a second monitor so I'll try moving it onto that when it happens next.
I've had a real deep dive into that log and have found the psu voltages, they are
12v @ 12.384v
5v @ 5..16v
3.3v @ 3.334v
not sure if thats under load or not, but for a psu of its age its seems to be holding its own, but that doesn't mean something could be wrong with it.
cpu vcore is around the 1.35-1.4v mark and for a 3700x thats totally normal under stock config the cpu core multiplier is anywhere from 34 - 42.8
I'm gonna keep looking for any info for the gpu, if i find any I'll be back :)
found the gpu, from the looks of it the core voltage is all over the place from 0.875v - 1.162v and the max temp i can see is 70 degrees @ 1084mhz core speed and the gpu power is around 70%.
all looks ok tbh, the fluctuations are the gpu boost algorithm kicking in
That's awesome thanks for looking into it for me :) I forgot to say that was whilst playing a game so it was under heavy load.
It sounds like it's a bit of a mystery then.
I'm thinking I might try sticking some more volts through the card and see if that makes it more stable?
i doubt more volts will help, most likely it may damage the card, have you tried a different screen or cable as other have suggested above first?
you could try a nvidia driver below v400.00, could be the new rtx features are mucking around with the card, head to this page
https://www.nvidia.com/Download/Find.aspx
and pick a couple of gtx 780 drivers from the list and have a play, there should be version's available from 382.33 upto 391.35 for your card
EDIT not sure if the link i provided above works properly anymore so below is another link to most of the driver releases for NVIDIA stuff
https://www.guru3d.com/files-categories/videocards-nvidia-geforce-vista-|-7.html
pick drives below v400.00 and see if the glitches go away
Slow reply as I've been doing more testing to try and get to the bottom of it.
I ran the built-in memory test and that seemed to report nothing was wrong - I was hoping it was something simple like this! I updated my chipset drivers yesterday and haven't tried a game yet to see it it crashes so hopefully this might help. If it doesn't ill try and see if I can roll the GPU drivers back even further like you suggest.
I thought I had cracked it though: on the occasions where it doesn't fully crash the machine (just the driver) or when I reboot and have the green pixels there still I decided to try the cable like @Tetras suggested. Pulling the DVI cable out the monitor end and putting it back in had no effect. Pulling the cable out the GPU and putting it back in seemed to fix it, strange. However it did start playing up again a day or two later - I'd played hours of games in the meantime, then as soon as it started playing up it crashed several times in a matter of minutes. I'd only been playing for a few minutes too so it wasn't temperature related.
Also another odd thing I've found - I've a second monitor connected so I tried moving a window over to that and the pixels problem didn't seem to exist there. I'm pretty sure I did but I can't remember if I tried switching the cables and ports around between the two monitors to see if the problem magically shifts onto the other one from now on - next time it does it I'll definitely do that.
Maybe this thing is just possessed? :p
one thing i forgot to ask is how old are you monitors and the cables, you said above moving over to a second screen made the glitches go away, could be something simple as you monitor may be on the way out, but if the pc keeps crashing i'd air on the side of caution regarding a dodgy screen, it could be driver related or hardware (exc psu), only way to find out is keep testing and try to replicate the problem :(
They're on my list of things to replace, two Dell Ultrasharps from ~2007. Didn't realise they were that old! No idea how old the cables are, I probably have some spare ones lying around somewhere though.
I'll wait and see if it crashes again and if it does I'll swap out to another monitor with HDMI on instead. Then if it crashes again I'll try a different PSU for the sake of it.
The annoying part is I can't easily trigger it so testing is a pain.
too add to this also is drivers, keep testing different versions from the guru3d link i posted above, i'd test one screen at a time swapping around plus the cables too if drivers and the screen idea fail to fix it then i'd look at another psu as you say above, wont lie gonna be a painful few days trying to work it out, but you'd be a more knowledgeable person afterwards :)
Windows 2004 has known issues. I installed it the other day and quickly reverted back to 1909 after it caused multiple BSOD's.
If you haven't done so already, I would recommend going back to that.
I generally found it to be much snappier on my PC but had some odd slowdowns on my laptop, I think it must be driver related as the task manager wasn't showing much going off.
I downgraded back to 1909 and played a day or two of games and everything seemed fine then last night it crashed again :(. It does seem to be fine for a day or two then go through a spait of crashing.
One thing I have noticed is that if I have multiple video sources playing that seems to aggravate it a lot more. E.g., playing a game fullscreen whilst leaving YouTube or something playing hidden away in the background. Maybe it's causing too much strain on the GPU and it's giving up, but it definitely seems to be a trigger.
that could be down to either the gpu or the psu, given that both are quite old now its tricky to know which one is at fault, but if you have a friend who could test your gpu to make sure its fine then i'd say the psu if bad, if the gpu still gives out weird glitches once tested in another pc then the gpu is bad.
either under high load the psu cant keep up or the gpu has a memory or core problem, if the crashing keeps happening i'd suspect the psu, because if a gpu fails thats it, you would get a black screen all the time or horrible artifacting sat in windows at idle
So a bit of an update, I swapped out to a spare PSU I had (750W OCZ something or other) and so far, touch wood, it hasn't crashed once.
I wonder if it was overheating or something? It didn't feel hot out the fan exhaust or anything, but it may explain why it could run fine for ages then suddenly start going on a crashing spree.
I'm not entirely sure it's fixed but let's hope so for now :D
if the spare psu you've swapped to has stopped the weird glitches and crashes i'd say it was the psu all along, given how old it is, it couldn't keep up with the power draw the components were asking of it, you've done the right thing in swapping as if you didn't and the old unit went pop it could have killed the whole pc, see how you get on with the spare psu and if everything works as intended job done :)
