Weird HDMI Motherboard Issue
22 Oct 2012
The Moon
Hi all,
Just finished building my new Z370 system and the only thing which is acting weird is the motherboard's HDMI port. When plugging in the cable it's all fine and posts a perfect image. However, the screen flashes black every so often. It's quite random and doesn't seem to be a result of CPU or GPU loads. Also, it tends to happen rarely. Please note, I'm connecting to an ultrawide 3440x1440 monitor.
I think the issue has stopped when dropping the resolution down to 2560x1080.
Do you think the HDMI port has a fault, or could be a software/monitor issue not liking the 3440x1440 resolution at 30Hz?
If you're going to continue using it I'd look in the BIOS and up the amount of main memory assigned to the iGPU to see if that fixes it.
Do you have just the one monitor or were you planning on running a 2nd off the iGPU. Personally I'd run both off the PCIe GPU.
I just have the one monitor and will use a 1080Ti powering 3440x1440 via DisplayPort. Noticed the HDMI issue just testing a new motherboard. So it's not a big deal as won't be used. Just a strange problem.
