Weird Issue with fan
Permabanned
6 Sep 2011
I have the Fractal Node 804. Great case. My favourite build yet. However... I have a weird issue with the fan controller it came with.
You can connect 3 to the fan controller using the typical 3 connector. But when my I switch it to Medium or High settings, the fan stops spinning and the LED's go off.
Its defiantly all connected as i thought it should be. The only other connection it has is to power the thing, which is done by a SATA power cable. The cable working because it has other things connected to it.
It cant be the fans either because i am using two different brands of fans it happens to all 3. Confused :S Am i doing something stupid
ALSO.... im getting temps at stock at about 35-40 on a 5820k? is that high?
Maybe the switch is broken. Maybe the load resistor for those settings is broken or non existant. Hard to tell without seeing the device.
